212
OxygenOS 5.0.8(HotFix) OTA for the OnePlus 3 & 3T
  1. C1544783500443
    Cupcake Dec 14, 2018
  2. G_Masoud_rasoolnejad_QDM
    Eclair Dec 14, 2018
  3. the_o2
    User of the Year 2018 Dec 14, 2018
    the_o2 , Dec 14, 2018 :
    But you said
    Btw
  4. Shivamsinha
    Shivamsinha , Dec 14, 2018 :
    Still waiting for pie.. it's almost end of December previously you said that it will be available from November hope by this update the battery drainage issue will be solved
  5. Bobbie63
    Marshmallow Dec 14, 2018
    Bobbie63 , Dec 14, 2018 :
    So when was that said? Link please.
  6. prasannaraja2
    Honeycomb Dec 14, 2018
  7. Bobbie63
    Nope, haven't been part of cbt, but I would say pie hasn't been tested on OP3(T)
    Sun90 and Ankitbhat12345 like this.
  8. prasannaraja2
    prasannaraja2 , Dec 14, 2018 :
    No Open beta testing as well as no closed beta testing
    Now i doubt on the performance and stability of pie update
    Can they do it on their own , what are your opinions @Bobbie63
  9. SandeepChouhan
    SandeepChouhan , Dec 14, 2018 :
    Thanks bro, will try
  10. 7045411438
    7045411438 , Dec 14, 2018 :
    when it will release in India ?
    UmarSyed456 likes this.
  11. bart877ie
    7045411438 likes this.
  12. sattogol
    Froyo Dec 14, 2018
    sattogol , Dec 14, 2018 :
    ~20 days waiting 5.0.7:
    nothing!
    now there is 5.0.8?!
    i love oneplus but this situation is ridiculous!
    sumit1626 and SandeepChouhan like this.
  13. ggkameleon
  14. ghostofcain
    ghostofcain , Dec 14, 2018 :
    What makes you think it's a small change?
    What situation?. Surely from reading this thread you know, it's an incremental roll out, and how to circumvent said roll out, so it's your choice to wait.
    The incremental roll out appears to have identified an issue hence the hot fix release, so all you waiters have been saved from the buggy release, why aren't you more thankful?
    From techopedia.com
  15. Blue-agila
    Ice Cream Sandwich Dec 14, 2018
    Blue-agila , Dec 14, 2018 :
    LOL
    Bobbie63, Auristic and ghostofcain like this.
  16. Bobbie63
    Sure, they have and are testing on OP5(T) and the six. OOS is in general the same. As long as they don't rush things, like some people want them to to, I see no reason why they can't give us a stable performance.
    andquester, nobraindk, jnsson and 4 others like this.
  17. PARTHI_SaNjay
    PARTHI_SaNjay , Dec 14, 2018 :
    Use Turbo VPN and set country as Germany and check for updates then you will get the update popup...after getting update notification disable VPN to download faster
    C1544783500443 likes this.
  18. markfoz
    markfoz , Dec 14, 2018 :
    Got the update yesterday, since updating my probe will only charge at normal speed well not do fast charge for some reason takes over an hour to go from 15-60%
  19. PCesar.Cercal
    KitKat Dec 14, 2018
  20. PCesar.Cercal
    KitKat Dec 14, 2018
