212
OxygenOS 5.0.8(HotFix) OTA for the OnePlus 3 & 3T
  1. Bobbie63
    Marshmallow Dec 14, 2018
    Bobbie63 , Dec 14, 2018 :
    Fixed it for you. :D
    Couldn't edit on my phone so had to use another device
    Ankitbhat12345 likes this.
  2. ghostofcain
    ghostofcain , Dec 14, 2018 :
    Using unofficial links is, obviously, at your own risk. Using a VPN or Oxygen updater merely accesses the update off of OnePlus' servers so is of no real concern.
  3. hamidiqbal
    Cupcake Dec 14, 2018
    hamidiqbal , Dec 14, 2018 :
    Hi OP .. I am encountering battery issues with my OP3 and It gets drain frequently. Any suggestions?
  4. Bierten77
    Froyo Dec 14, 2018
    Bierten77 , Dec 14, 2018 :
    -U can use Tunnel Bear to "activate" the update and then switch it off to download it.-
  5. F_Rohit_Bapat_kBaL
    Froyo Dec 14, 2018
  6. Ankitbhat12345
    Jelly Bean Dec 14, 2018
    Ankitbhat12345 , Dec 14, 2018 :
    Got it :D
    Bobbie63 likes this.
  7. YudhPK
    Donut Dec 14, 2018
  8. Arbingr8
    Honeycomb Dec 14, 2018
    Arbingr8 , Dec 14, 2018 :
    Disable Google app. Not Google play or services...
  9. henio81
    henio81 , Dec 14, 2018 :
    Can somebody explain me... i have a beta 30 if i will swap for a stable i gona lost ma data? What is the easiest way to do this. Tanky you.
  10. Ankitbhat12345
  11. Ankitbhat12345
    Yes u have to wipe data for clean installation. So take a backup then install :)
    ghostofcain likes this.
  12. ghostofcain
    If there was no problem with 5.0.7, do you think they'd be issuing a hotfix?
    Read the OP of the beta thread and follow the instructions, and yes you will lose all data, but then I can't imagine anyone would test beta software without a robust backup regimen, surely?
    Auristic likes this.
  13. G_Krzysztof_Karwoski_LPa
  14. Arbingr8
    What will happen if somebody downloaded 5.0.7??
  15. markfoz
    markfoz , Dec 14, 2018 :
    Possibly the worst ôta upgrade EVER!
  16. ghostofcain
    And installed it? They will get the hotfix update via OTA.
    Definitely the worst feedback EVER!
    Auristic, Bobbie63 and nobraindk like this.
  17. Cervantes
    Lollipop Moderator Dec 14, 2018
    Cervantes , Dec 14, 2018 :
    You did not find this thread
    The update thread is a thread of questions
    Please, read the first post
    use the topic search instead of opening a new thread
    Thread merged
  18. V1543866948841
  19. V1543866948841
    UmarSyed456 likes this.
  20. V1543866948841
