212
OxygenOS 5.0.8(HotFix) OTA for the OnePlus 3 & 3T
  1. ghostofcain
    Marshmallow Dec 14, 2018
    ghostofcain , Dec 14, 2018 :
    Sorry try with a different translator.
    andquester and Auristic like this.
  2. Karsten Lange
    Cupcake Dec 14, 2018
    Karsten Lange , Dec 14, 2018 :
    Hello,
    after the installing of the Update i have Problems with battery drain. And my 3T get warmer/heatet up more than normal by onscreen and normal use.
    Have an one the same Problems?
    Ankitbhat12345 likes this.
  3. ghostofcain
    That's perfectly normal in the first four or five charge cycles after an update.
    Auristic and UmarSyed456 like this.
  4. a.594
    Donut Dec 14, 2018
    a.594 , Dec 14, 2018 :
    after this update the battery performance somehowt is much much better than before! thanks for the hard work I really appreciate the support for the last 2 and half years. I have one plus 3 btw.
    Roy91 and Karsten Lange like this.
  5. Karsten Lange
    Cupcake Dec 15, 2018
    Karsten Lange , Dec 15, 2018 :
    Thank you for the Information. I will test it. [e]1f609[/e]
  6. mahendra.srivastava
    Donut Dec 15, 2018
    mahendra.srivastava , Dec 15, 2018 :
    For some strane reason I did a local upgrade to 5.0.8 and I got both networks back and everything working.
  7. Sachin B Suresh
  8. Pranjulrajput
    Eclair Dec 15, 2018
    UmarSyed456 likes this.
  9. M1544812394781
    M1544812394781 , Dec 15, 2018 :
    Back to Oos 5.08 from beta, dloaded the update file, flashed from stock recovery, wiped user data, all is working well. Good battery backup. Thanks people for all the info. 1plus 3
    Roy91 and UmarSyed456 like this.
  10. Mannoj5
    Donut Dec 15, 2018
  11. Mannoj5
    Donut Dec 15, 2018
    Mannoj5 , Dec 15, 2018 :
    download VPN master from playstore > Set to 'Germany' > Server 1 or 2 or 3 & now open System Upadte in settings! Simple! #Chill
  12. UmarSyed456
    Gingerbread Dec 15, 2018
  13. UmarSyed456
    UmarSyed456 , Dec 15, 2018 :
    can't we update without vpn
  14. VaibhavBhargava
    Lollipop Dec 15, 2018
    VaibhavBhargava , Dec 15, 2018 :
    They should
  15. Mannoj5
    Donut Dec 15, 2018
    it takes 3-4 minutes time to show update after VPN is set... patience bro
    iqbalanis and UmarSyed456 like this.
  16. UmarSyed456
    no update without vpn right?
    iqbalanis likes this.
  17. I1515093297327
    Donut Dec 15, 2018
    I1515093297327 , Dec 15, 2018 :
    I NEED AN ANSWER!
    Is it going to fix low sound volume issue or not.?
    Because you could read how many feedbacks about it and when I contacted with customer care they informed it's HARDWARE not SOFTWARE problem!!!
    I really do like Oneplus but I don't trust them anymore.
  18. UmarSyed456
    you need to visit service centre for this
  19. UmarSyed456
  20. I1515093297327
    Donut Dec 15, 2018
