212
OxygenOS 5.0.8(HotFix) OTA for the OnePlus 3 & 3T
  1. X1537722071448
    Cupcake Dec 22, 2018
    X1537722071448 , Dec 22, 2018 :
    The Back and Recent buttons stopped working after installing this update , Also the phone is not able to multitask well after this recent fixes. Severe Battery Drain can also be observed.Please look into and release the new Bug Fix update as soon as possible..
  2. Topper_Gas
    KitKat Dec 22, 2018
    Topper_Gas , Dec 22, 2018 :
    OP won't be releasing a bug fix for just our own phone!!!
  3. K1543158258599
    Froyo Dec 22, 2018
  4. X1537722071448
    That's actually Common Sense , No one expects a single update for your own phone from the OnePlus Team. If you are facing any issues, you are free to state the problem in the discussion and not quoting unnecessarily for no reason...
  5. Blue-agila
    Ice Cream Sandwich Dec 22, 2018
    Blue-agila , Dec 22, 2018 :
    No. Only you
    Auristic likes this.
  6. ghostofcain
    Marshmallow Dec 22, 2018
    ghostofcain , Dec 22, 2018 :
    Yes but, if after READING the thread, it dawns on you that YOU appear to be the only user reporting / experiencing YOUR specific problems then just maybe the issue isn't with the build but with your specific setup?
    Auristic and lkosova like this.
  7. N1545506202761
  8. jrsamp
    Gingerbread Dec 22, 2018
    jrsamp , Dec 22, 2018 :
    This OTA update only arrived today, via normal. 22 days after being announced by Oneplus.
    It's normal? We have to assume that in order to pull an update from Oneplus in a timely manner, in Portugal, do we really have to use VPN?
  9. ghostofcain
    If you want to circumvent the incremental roll out, yes.
  10. Satya U
    Froyo Dec 23, 2018
    Satya U , Dec 23, 2018 :
    my earpiece volume became very less after this update. any fix please?
  11. ghostofcain
    Marshmallow Dec 23, 2018
    ghostofcain , Dec 23, 2018 :
    It's a hardware issue, visit service centre. If you don't believe me roll back the OS and report your results.
    Chirag AM and Auristic like this.
  12. chandramoulipolavarapu
    Honeycomb Dec 23, 2018
    chandramoulipolavarapu , Dec 23, 2018 :
    hey, I know it's wrong thread, but tell me ur valid reasons:
    if u shot using normal camera mode with shaking hands and moving on vehicle it is some what difficult to take the shot without blur, but if we keep on shooting the same scenery with 1080p with 60fps and mean while take some snaps while video recording is on u will get same scenery images without blur in max cases why can't they implement the same kind of thing while using normal camera mode
  13. chandramoulipolavarapu
    why the overall image is grainy , if u keenly observe the image by zooming, there is grainy effect in overall photo, I know there is little bit low light but, it isn't that low w.r.t normal day light.. for ur info my app is default one , I used all settings in auto mode while taking the photo, I flashed this version few days ago, still slight lag in Google feed scrolling, Netflix isn't fluid when compared to s8, decreased animation speeds, I personally flashed THIS VERSION of Os..
  14. G_Thomas_S_PyvV
    G_Thomas_S_PyvV , Dec 23, 2018 :
    Anti virus are useless on Android.
    And you're on a Oneplus 3T thread
    jnsson likes this.
  15. SankarHarry
    Eclair Dec 23, 2018
    SankarHarry , Dec 23, 2018 :
    yes am feeling the same bro. after the update. Dash charger seems to be slow. before update it won't took that to reach 90%
  16. tpati
    Gingerbread Dec 23, 2018
    tpati , Dec 23, 2018 :
    Anyone have cell standby drain problem on this version? On 5.0.6 didn't have it..
  17. MrHari_theCarguy
    Jelly Bean Dec 23, 2018
    MrHari_theCarguy , Dec 23, 2018 :
    why does phone feel a bit sluggish when using for the first time like in transitions and animations after installing an OTA update and wiping cache from recovery.is this normal?
  18. Pakly
    Cupcake Dec 23, 2018
  19. ghostofcain
    After a cache wipe your device is rebuilding it, hence it can be a little sluggish and use more battery than expected until cache is rebuilt.
    MrHari_theCarguy likes this.
  20. Dineshbhati738
    Dineshbhati738 , Dec 23, 2018 :
    my mobile same problem after update
    sound very lowest in calling
