212
OxygenOS 5.0.8(HotFix) OTA for the OnePlus 3 & 3T
  1. ghostofcain
    Marshmallow Dec 30, 2018
    ghostofcain , Dec 30, 2018 :
    Obvious to you maybe, the way to change it is fairly self explanatory Screenshot_20181230_170309_com.brave.browser.jpg
  2. ghostofcain
    They are your apps with updates, view your installed apps instead.
    Try, reading, the android P thread then, this is for discussion of 5.0.8!
  3. B.yashaswi
    Ice Cream Sandwich Dec 30, 2018
    B.yashaswi , Dec 30, 2018 :
    Okay now i made it public and it is showing that to contact administrator for any changes
  4. dimovkster
    Gingerbread Dec 30, 2018
    dimovkster , Dec 30, 2018 :
    this tab is the recently updated ones. all of the installed apps are in the second tab, check there
  5. G_Sergio_Encinas_Ruiz_de
    Eclair Dec 30, 2018
    G_Sergio_Encinas_Ruiz_de , Dec 30, 2018 :
    now it's working, I do a wipe cache and it works. The problem now is when I'm going to install a app, it only stay "downloading" and never install
  6. Murali Krishna 3320
    Eclair Dec 30, 2018
  7. tushar.mokal
    Froyo Dec 30, 2018
    tushar.mokal , Dec 30, 2018 :
    It's working fine, I am using it.
    a5pe4 likes this.
  8. tushar.mokal
    Froyo Dec 30, 2018
    After 2 - 3 charging cycle it's normal. I personally didn't find any issue.
  9. Murali Krishna 3320
    Eclair Dec 30, 2018
    Murali Krishna 3320 , Dec 30, 2018 :
    TQ bro for info I am updating now :)
  10. wospino
    Honeycomb Dec 31, 2018
    wospino , Dec 31, 2018 :
    you may be need to to do a clean install (with factory reset and reinstall)
  11. Ankitbhat12345
    Jelly Bean Dec 31, 2018
    Ankitbhat12345 , Dec 31, 2018 :
    Same here
  12. BeingIncog
    Nougat Dec 31, 2018
    BeingIncog , Dec 31, 2018 :
    Contact any mod of your choice, via forum pm, they will contact admin to change to correct one!!!
    B.yashaswi likes this.
  13. Zahid Ali cheema
    Donut Dec 31, 2018
    Zahid Ali cheema , Dec 31, 2018 :
    after updating some part of oneplus 3T screen is not working. like he cant type these alphabets uighjbn and also parallel to these alphabet other part of screen in not working. need help in this regards
  14. Ibrahim Attar
    Ibrahim Attar , Dec 31, 2018 :
    Internet is not stable while video streaming need to turn off and turn on wifi every time, wiping cache not helpful.
  15. AhmedZunaid
    AhmedZunaid , Dec 31, 2018 :
    The whole onplus theme color is RED, still they don't have it in the Accent color on the oneplus 3/T. But nobody's talking about that, they just want new thing happening in their lives, Hence the cry for updates.
  16. Rafal Jozwiak
    Froyo Dec 31, 2018
    Rafal Jozwiak , Dec 31, 2018 :
    Hey I don't know if this will help but have you tried to clear cache for Google Play store only in settings? I had similar problem and i couldn't install any updates but this solved my problem.
  17. ghostofcain
    Marshmallow Dec 31, 2018
    ghostofcain , Dec 31, 2018 :
    Damn right where have people's priorities gone, preferring an updated OS to new accent colours!
    One word "Substratum"
  18. V!nayak
    Gingerbread Dec 31, 2018
  19. JohnnyBramble
    Eclair Dec 31, 2018
    JohnnyBramble , Dec 31, 2018 :
    I can see all the installed apps on the list in Play Store, but I haven't received any app update for several days. Weird...
  20. ghostofcain
    You never know maybe app devs have something on at this time of year? BTW you can always check when apps where last updated on their app store pages.
