1006
OxygenOS 5.0, our first official Android O OTA update for the OnePlus 3 and 3T
  1. Deactivated User
    Dec 18, 2017
    nope1nope likes this.
  2. dcop7
    Honeycomb Dec 18, 2017
    dcop7 , Dec 18, 2017 :
    4.1kb cache? But that is causing problems?
  3. Bobbie63
    Nougat Dec 18, 2017
    Bobbie63 , Dec 18, 2017 :
    Yes, I still don't understand how that could be a problem.
    Just imagine 4.1 KB, all that wasted space. :D
    Sun90 likes this.
  4. Sun90
    Starting Point Expert Community Expert Dec 18, 2017
    Sun90 , Dec 18, 2017 :
    They took users data without consent.:p
    They took battery life, update after update.:p
    Now they are taking the cache bit by bit:D
    lkosova, sharadkatti and Bobbie63 like this.
  5. Bobbie63
    Nougat Dec 18, 2017
    Well, with a speed of 4.1 KB/few days, soon you'll run out. :D
    Sun90 likes this.
  6. Sun90
    Yes.
    Either they stop it or give us expanded storage facility with software update:D
    lkosova and Bobbie63 like this.
  7. Deactivated User
    Dec 18, 2017
  8. Sun90
    Will pray God ,you will be jobfull at the earliest.:p
    Bobbie63 likes this.
  9. Bobbie63
    Nougat Dec 18, 2017
    And you probably won't be able to get rid of it as Oreo handles cached data differently as previous.
    You might call yourself lucky being able to easily wipe cached data having a oneplus, other phones, it's a lot of more work.
    http://mobileinternist.com/clear-cache-android-oreo
    Deactivated User likes this.
  10. dcop7
    You know that android needs to create cache. Every app create cache. Most probably, it is the settings "app" that creates the 4.1 kb right after you delete the cache. Nothing you can do. It is normal behavior.
    DrVikTroll likes this.
  11. f00tbaLL
    Gingerbread Dec 18, 2017
    f00tbaLL , Dec 18, 2017 :
    Quick question so is that the last update for the 3T apart from security updates from now on?
  12. RakeshNandal
    Cupcake Dec 18, 2017
  13. HARI_HP
  14. relaxer
    relaxer , Dec 18, 2017 :
    I am the only one with this? Happened this to nobody else yet?
  15. Bobbie63
    Nougat Dec 18, 2017
    This one? Nope, from what I understood, you'll get an update to 8.1.1 also
  16. Ricky1394
    Ice Cream Sandwich Dec 18, 2017
    Ricky1394 , Dec 18, 2017 :
    M also facing Same problem of lift up display....
    And I don't think cleaning cache helping this out coz I have tried every possible tweaks from my end.
    May be next stable update will solve this issue..
  17. Aeron
    Aeron , Dec 18, 2017 :
    I have not noticed anyone else complaing about it. Maybe you can give us a bit more info so anybody can recognize problem.
    What did you do with the phone before reboot ?
    Any app running ?
    Any log from before reboot ?
    Was phone too hot ?
    Did it happen again or was it that one time?
  18. Gaurav Goenka
    Donut Dec 18, 2017
  19. G_juan_antonio_rodrigo_L
    Eclair Dec 18, 2017
    G_juan_antonio_rodrigo_L , Dec 18, 2017 :
    [QUOTE = "G_sumit_azad_sMQC, post: 17349126, member: 944404"] Compruebe por favor que su auricular está perfectamente claro, ya que también he enfrentado este problema, el auricular puede bloquearse fácilmente por la suciedad y debe ser aprobado por cualquier profesional del servicio. [/ QUOTE ]
    nos pasa a un numero grande de personas, por lo que o es de software o es una partida defectuosa de altavoces.
    a mi me pasa desde 4.5.1 y en 5.0 se ha agravado.
    norte funciona ni reset de fabrica ni wipe ni nada.
  20. lacico
    Donut Dec 18, 2017
    lacico , Dec 18, 2017 :
    Is there anyone Who have sound problem?Sometimes every sound (notification,video,music,ring,alert)lowers without a reason,if I restart problem disappeared but however after some hours return to the minimum independently
