1006
OxygenOS 5.0, our first official Android O OTA update for the OnePlus 3 and 3T
  1. Noykps
    Cupcake Dec 20, 2017
  2. SanthoshGurram
    Honeycomb Dec 20, 2017
    SanthoshGurram , Dec 20, 2017 :
    Nope.
    May be they will bring this feature in 8.1 update !
  3. priyanshugupta9
    Gingerbread Dec 20, 2017
    priyanshugupta9 , Dec 20, 2017 :
    Somehow, your replies seems sane this time around. Looks like someone taught you some manners in the last few months?
  4. Bobbie63
    Nougat Dec 20, 2017
    Bobbie63 , Dec 20, 2017 :
    I don't need to be taught manners, asI had the honor to get raised in an appropriate way and got good education as most people have in my country, something that can't be said of some people on this forum.
    *tapping ignore*
    lkosova and Sun90 like this.
  5. kunal.shukla
    kunal.shukla , Dec 20, 2017 :
    It is available in Oxygen OS 5.0.
  6. F_Gowtham_Chowdary_ghXr
  7. priyanshugupta9
    Cute :)
  8. dcop7
    dcop7 , Dec 20, 2017 :
    First, next time, use a better title. If anyone that have problems used "Need Help", it was a mess.
    The Oreo update was removed. You can still update via oneplus site. But wait for the next update, it is better.
  9. ghostofcain
    Marshmallow Dec 20, 2017
    ghostofcain , Dec 20, 2017 :
    And you are unable to search, both the forum and the Internet? It's just not your lucky day is it.
  10. Aeron
    Aeron , Dec 20, 2017 :
    wrong forum category. Try to ask in the one related to Oneplus 5.
    ghostofcain likes this.
  11. Spike83420
    Spike83420 , Dec 20, 2017 :
    Anyone experiencing problems with volume it's the only bug I've had since the last three updates it's kind of annoying
  12. Gladders
    Gladders , Dec 20, 2017 :
    I'm also having the sound bug, didn't hear the alarm this morning as it was that quiet.
    sometimes the sound works sometimes it doesn't.
    I did a full factory reset after upgrading to OOS5 and also cleaned the cache.
  13. PTuT
    Jelly Bean Dec 20, 2017
    PTuT , Dec 20, 2017 :
    I read enough. What matter is to stay polite.
    megamock and Bobbie63 like this.
  14. G_juan_antonio_rodrigo_L
    Eclair Dec 20, 2017
    G_juan_antonio_rodrigo_L , Dec 20, 2017 :
    [QUOTE = "G_michael_dickshinski_aC, post: 17362668, member: 847503"] Cualquiera que tenga problemas con el volumen en el único error que haya tenido desde las últimas tres actualizaciones, es algo molesto [/ QUOTE]
    yo igual. no oigo hay casi la voz de la persona que me llama. ni hard reset ni wipes ni nada funciona
  15. Darekb81
    Darekb81 , Dec 20, 2017 :
    English please!
  16. F_Harihara_Jothi_PbhN
    F_Harihara_Jothi_PbhN , Dec 20, 2017 :
    my op3t has not received the Oreo update yet ...when i check my settings...it says it's up to date but it's still in nougat ...
    could anyone clarify me that am I the only one who haven't received update via OTA !!!
  17. gazz1701
    gazz1701 , Dec 20, 2017 :
    OnePlus pulled the OTA - assume temporarily and assume as lots of people were reporting issues (although been fine for me).
    If you wait then a new OTA will hopefully surface in the near future, and you will see a notification.
    If you want the current build now, download file from their web site and install manually (search for instructions).
    pgn0 likes this.
  18. G_Justin_Bhola_qQOY
    G_Justin_Bhola_qQOY , Dec 20, 2017 :
    Download opera VPN from playstore and then select Canada then go to your phone settings and try updating your phone. It should be able to work.
  19. 1tseddy
    Froyo Dec 20, 2017
    1tseddy , Dec 20, 2017 :
    use any vpn app like tunnel bear or opera vpn, and den set your location to cannada, and den check your update, the moment you start downloading update, remember to turn off vpn for faster download.
  20. ghostofcain
    Yep just you, in future it's always a good Idea to drop in on the release thread that way you'll have the latest info and avoid the stigma of being the last person on the planet to recieve your OS update.
    Sun90 and Deactivated User like this.
