617
OxygenOS 5.1.1 OTA for the OnePlus 5 & 5T
Thread Status:
Not open for further replies.
  1. MentalDraco
    Marshmallow Apr 18, 2018
    MentalDraco , Apr 18, 2018 :
    Hey I heard a lot of ppl reporting network boost feature was missing any info on that ?
  2. G_Rohit_Sarna
    Gingerbread Apr 18, 2018
    Apin Iroth likes this.
  3. Saisibi Suresh
    Honeycomb Apr 18, 2018
    Saisibi Suresh , Apr 18, 2018 :
    wait for it. it would reach you pretty soon. if you are eager, download from oxygen updater app in play store.
  4. Manu MK
    Eclair Apr 18, 2018
  5. X1513001495748
    SnoopBok likes this.
  6. olliware
    Cupcake Apr 18, 2018
    olliware , Apr 18, 2018 :
    Be patient. As always the update is being deployed incrementally for certain known reasons. New update, same procedure [e]1f609[/e] !
    j.ong likes this.
  7. cozgunay
    Donut Apr 18, 2018
    cozgunay , Apr 18, 2018 :
    Is there anyone who meets problem with animations? I mean since the update of OS5.1.0, I met slow down on my device. For instance, I open Outlook app, and it is getting slower during passing to another transaction or menu. I faced same problem in other applications as well. When I clear cache, everything is okay. but after sometime, the problem repeats. My device is OP5 - 8gb RAM - 128gb ROM
  8. Madan Raj D
    Madan Raj D , Apr 18, 2018 :
    yea stable but incremental... which means there will be more updates following!
  9. A51f
    Donut Apr 18, 2018
  10. Zubair_Ahmed007
    Donut Apr 18, 2018
    Zubair_Ahmed007 , Apr 18, 2018 :
    Is there anyway of using on display Screen Off when using the navigation gestures?
  11. coolapratik
    Eclair Apr 18, 2018
    coolapratik , Apr 18, 2018 :
    just use a vpn app and connect with germany netherland or canada's vpn n then check for update
  12. buruaden786
    buruaden786 , Apr 18, 2018 :
    These are my battery stats from 100% to 4% after 8.1 on 5T
  13. buruaden786
  14. Mr_Cyrox
    KitKat Apr 18, 2018
    Mr_Cyrox , Apr 18, 2018 :
    Just use Opara VPN, set up on Canada, search for update...
    Or use Oxygen updater app from play store...
  15. Sona.Hora
    Donut Apr 18, 2018
    Sona.Hora , Apr 18, 2018 :
    unfortunately this update killed my LTE speed. I was getting LTE speeds around 70 to 90 MBPS and now max goes upto 28 or 30mbps. anyone else having similar issues?
  16. izzykasha
    Lollipop Apr 18, 2018
    izzykasha , Apr 18, 2018 :
    you get a string instrument?
    Viola lol
  17. SquashyBurk
    SquashyBurk , Apr 18, 2018 :
    Hi, may I ask what launcher you are using? That is a beautiful looking home screen with the dock at the bottom.
  18. Rakesh_Kumar_T_
    Jelly Bean Apr 18, 2018
    Rakesh_Kumar_T_ , Apr 18, 2018 :
    mine is 764 MB in OnePlus 5t , is this a new version than others who posted in this thread? I got the update today ( 18-04-2018) via Canada Vancouver VPN
  19. IsseiSenpai
    Froyo Apr 18, 2018
    IsseiSenpai , Apr 18, 2018 :
    Lol, its no different.
  20. AnishBmMindfreak
