617
OxygenOS 5.1.1 OTA for the OnePlus 5 & 5T
Thread Status:
Not open for further replies.
  1. elanglois
    Lollipop Apr 20, 2018
    elanglois , Apr 20, 2018 :
    That's Google Chrome
    Type this URL
    chrome://flags/#enable-chrome-home
    Set the feature shown to enabled
    A swipe up on the URL bar gives you shortcuts and recommendations, and you can swipe it left and right for changing tabs. I really like it. It takes awhile to get used to the bar being at the bottom, but its better, especially if you use hardware buttons or 5T gestures. If you use on-screen navbar, you may find it crowded.
    lovebeam likes this.
  2. R1522336217303
    Cupcake Apr 20, 2018
  3. Gopinath Prasad
  4. Pisticiuc Iustin
  5. Sam edward
  6. Sam edward
  7. danishdaycare
    Ice Cream Sandwich Apr 20, 2018
    danishdaycare , Apr 20, 2018 :
    By reading how to. None will do that for you.
  8. danishdaycare
    Artemus likes this.
  9. ALy Enache
    ALy Enache , Apr 20, 2018 :
    cu aplicatia Turbo VPN din play store
  10. danishdaycare
    Kayone007, Evgeny.S and Artemus like this.
  11. ravibs77
    Donut Apr 20, 2018
    ravibs77 , Apr 20, 2018 :
    use ok Google voice or u can find Google Assistant app in play store
  12. danishdaycare
    Could be many reasons. First, read first post in this thread..
  13. B1518633950830
    Eclair Apr 20, 2018
    B1518633950830 , Apr 20, 2018 :
    why the notification panel is changed in 5.1 update.can't see any additions in it but grabbed quarter of the display.it doesn't make any sense. it looked clean on previous update. the other part of 5.1 updates are good as if now. i wish OP fix this soon.
  14. danishdaycare
    Some yes. Some no. Impossible question to get clear answers ..
  15. danishdaycare
    No. Noone will fix it. It's normal after a update. Give it some time. Then, investigate for yourself! Clear cache in recovery. Check your apps, maybe some of them are shitty. Please make an effort to solve something yourself, it works flowless for me and MANY others.
  16. danishdaycare
    Cle
  17. ChefChaudart
    Honeycomb Apr 20, 2018
    Sam edward and sai.wayne like this.
  18. danishdaycare
  19. G_T_Bennett
    Jelly Bean Apr 20, 2018
    G_T_Bennett , Apr 20, 2018 :
    This is the new norm. Don't hold your breath. It's really not that bad.
  20. CHAND555
    CHAND555 , Apr 20, 2018 :
    After getting update to 8.1 my 5t....battery draining fast and sound become low n unclear
