617
OxygenOS 5.1.1 OTA for the OnePlus 5 & 5T
Thread Status:
Not open for further replies.
  1. Ravi Mafalus
    Ice Cream Sandwich Apr 20, 2018
  2. CHAND555
    Cupcake Apr 20, 2018
  3. C1524213373670
  4. vasanth88j
    Froyo Apr 20, 2018
  5. vasanth88j
    Froyo Apr 20, 2018
    vasanth88j , Apr 20, 2018 :
    you can update to 8.1 , changing vpn server to canada
  6. soumyadg
    soumyadg , Apr 20, 2018 :
    There is an issue with the ringtones going off again. Anyone facing the same issue?
  7. B1517477284086
    B1517477284086 , Apr 20, 2018 :
    How do we use split screen after enabling the navigation gestures? was just trying to compare two tables but eventually had to enable the navigation bar.
  8. Tanay02
  9. H1519548376884
    Gingerbread Apr 20, 2018
    H1519548376884 , Apr 20, 2018 :
    when i open the app drawer.
    when it opens and reaches at top.
    it stops in between and then it opens completely.
    its very annoying.
    anybody else facing this issue?
    i tried nova launcher but same issue taking place in it also.
    its like it goes at top position and then locks there
  10. vasanth88j
    Froyo Apr 20, 2018
    download turbo vpn app from playstore, connect it to canada vpn, goto settings search for updates and upgrade thats it
  11. Tanay02
    Tanay02 , Apr 20, 2018 :
    Even if I'm using mobile internet?
  12. ajaynargas
  13. shashi347kant
    Donut Apr 20, 2018
  14. ajaynargas
  15. Yousufrashid
    Yousufrashid , Apr 20, 2018 :
    Hi
    Sir I am from India and new user of One Plus .I recently upgraded to One Plus 5T and don't know how to update to Oxygen OS 5.1.0.Kindly guide me for the updation and let me know whether I will recieve Stable Version via OTA or not
    Thanks
    yousufrashid
  16. midhunpmadhav
    midhunpmadhav , Apr 20, 2018 :
    Can not create new backup in OnePlus Switch after 8.1 update. Application crashes on new backup button click.
    Anag hegde likes this.
  17. vasanth88j
    Froyo Apr 20, 2018
    yes you can, if you have lot of data to spare
    I1524214668534 likes this.
  18. ajaynargas
    ajaynargas , Apr 20, 2018 :
    You go to settings and scroll down to system update. Check If Update rec'd .If so down load and rest it will do for you.Make sure your battery is around 70% atleast before you do .l have not rec'd any update till date for OS 5.1.0
  19. Yousufrashid
    Thanks Sir I have checked it but haven't received any above os 5
  20. Tanay02
    is it safe to download using VPN. it doesn't crash the system or make it slower, right?
