617
OxygenOS 5.1.1 OTA for the OnePlus 5 & 5T
Thread Status:
Not open for further replies.
  1. lovebeam
    Froyo Apr 20, 2018
    lovebeam , Apr 20, 2018 :
    i faced horrible lags after updating while scrolling left and right on home screen. anyone else with the same?
    i did reset the cache.
  2. prajeetmadkaikar
    Donut Apr 20, 2018
  3. iammisternice
    Cupcake Apr 20, 2018
    iammisternice , Apr 20, 2018 :
    I havnt received any update notification
  4. idkwhoiam322
    Nougat Apr 20, 2018
    idkwhoiam322 , Apr 20, 2018 :
    All you can do is wait because:
    Unless you want to update using a VPN(Set to Germany or Canada) or flash the full zip from recovery.
  5. Gopi Kiccha
    Gingerbread Apr 20, 2018
  6. G_T_Bennett
    Jelly Bean Apr 20, 2018
    G_T_Bennett , Apr 20, 2018 :
    And where did you hear this?
  7. vaibhavchavan512
    vaibhavchavan512 , Apr 20, 2018 :
    it's me[e]1f602[/e][e]1f602[/e][e]1f602[/e] company employ
  8. Kayone007
    Kayone007 , Apr 20, 2018 :
    how miracast behaviour with this update? does this broken feature revived by this update?
  9. cristian.radulescu
    Donut Apr 20, 2018
    cristian.radulescu , Apr 20, 2018 :
    Salut. Ai facut update de la Open Beta? Eu am incercat solutia asta cu VPN-ul, insa nu imi apare niciun update momentan, fiind pe Open Beta... Multam!
  10. Pisticiuc Iustin
    Pisticiuc Iustin , Apr 20, 2018 :
    Salut! Aveam softul original. Nu aveam instalată nicio versiune beta
    cristian.radulescu likes this.
  11. G_T_Bennett
    It's not really funny as many users who don't know better will ask unnecessary questions about this. Especially for a gradual update release.
  12. Pisticiuc Iustin
    Dar citisem undeva că trebuie să ai instalată versiunea originală ca să poți primi update-urile oficiale
  13. cristian.radulescu
    Donut Apr 20, 2018
    Do you know if this VPN solution works also if you have the latest Open Beta? Or is this release only working for previous stable release?
  14. cristian.radulescu
    Donut Apr 20, 2018
    Eu am instalata versiunea originala, cum ii zici tu. Am, practic, Oxygen OS versiunea beta bazata pe Android 8.1, instalata pe caile oficiale de la OnePlus. In mod normal, ar trebui sa vina un update stable peste acest Beta, insa probabil ca e diferit de cel ce a fost lansat deja.
    In trecut am avut Nexus si era acelasi mod de lucru daca te inrolai in beta-uri. La un moment dat, primeai OTA stable release.
  15. G_T_Bennett
    It has worked for users simply loading it over the previous Beta. Personally I would recommend a full wipe before upgrading.
  16. cristian.radulescu
    Donut Apr 20, 2018
    Do you mean local install of zip file? I was wondering about OTA. I read a post saying that one might install a VPN app, connect to a Canadian server and try Update in settings, in order to receive OTA. This method didn't work in my case and I was wondering whether not getting the OTA yet has to do with my phone having a Beta version...
    I could of course, download and install zip file, however I was afraid of possible errors, since that doesn't appear to be an incremental file...
    I'm more accustomed to Nexus style of sideloading updates and they had 2 types of files: incremental and full files.
    Do you suggest that it's ok to install the zip mentioned in post no. 2 over the Beta, without wiping data? I wouldn't want to wipe data... :)
  17. Pisticiuc Iustin
    Am avut și eu în trecut Nexus, dar cei de la Oneplus au zis că ai nevoie de versiunea stabilă că să poți primi update-urile finale.
  18. cristian.radulescu
    Donut Apr 20, 2018
    Sper ca n-ai dreptate, ca downgrade n-am chef sa fac! :)
    Adica banuiesc ca se lasa cu full wipe si n-as vrea asta...
  19. bharat_trouper
  20. Prince aamir
    Froyo Apr 20, 2018
    Prince aamir , Apr 20, 2018 :
    still not received in india to anyone
    G_Bharat_Prabhas_NjsN likes this.
