617
OxygenOS 5.1.1 OTA for the OnePlus 5 & 5T
Thread Status:
Not open for further replies.
  1. sarabaz
    Eclair Apr 21, 2018
    sarabaz , Apr 21, 2018 :
    having excessive noise in picture and ringtone is not working while someone calls us ...after updating to 8.1.0 pls fix with bug fix update
  2. Cervantes
    Lollipop Moderator Apr 21, 2018
    Cervantes , Apr 21, 2018 :
    Thread meged
    Please, read the first post
  3. n@ren_armybrat
    Donut Apr 21, 2018
    n@ren_armybrat , Apr 21, 2018 :
    how can I use a VPN.. guide me.
  4. D1517844581455
    Honeycomb Apr 21, 2018
    D1517844581455 , Apr 21, 2018 :
    download opera vpn (or any other app from the play store).
    choose to "activate guardian"
    connect to WiFi
    change region to Canada or germy
  5. n@ren_armybrat
    Donut Apr 21, 2018
    is it safe to do so. After using VPN, it remain a stable version or what?
  6. G_Peri_Arun_dZGv
    Cupcake Apr 21, 2018
  7. I1517949815226
    I1517949815226 , Apr 21, 2018 :
    The new navigation gestures are awesome! I don't care if they're copying Apple or not, it just works great and it's definitely better than the buttons. Now I will never again hit the home button instead of the space bar on my keyboard while I'm typing. God that was so annoying!
    Thank you, you've done a great job.
    Rakshit_Patil, btraju143 and Venchy like this.
  8. D1517844581455
    the update gets rolled out in batches. so it may take some time to get to your device
  9. G_Peri_Arun_dZGv
    G_Peri_Arun_dZGv , Apr 21, 2018 :
    it's testing our patience real bad. as the current Version feels buggy
  10. D1517844581455
    the new gestures also makes use of the entire display as opposed to the earlier software keys which took a lot of space off the screen!! really loving the gestures:)
    Venchy and I1517949815226 like this.
  11. D1517844581455
    absolutely safe. no harm at all. you can switch off the VPN once you start downloading the update!!
  12. D1517844581455
    use a VPN then. no problems
    G_Peri_Arun_dZGv likes this.
  13. n@ren_armybrat
    Donut Apr 21, 2018
    ok.. thnk u so mch
  14. troyvhaar
    Donut Apr 21, 2018
    troyvhaar , Apr 21, 2018 :
    The rollout is great
    chintanmn likes this.
  15. E1520415845069
    Eclair Apr 21, 2018
  16. D1522298191848
    Donut Apr 21, 2018
    D1522298191848 , Apr 21, 2018 :
    People!! Is it worth if I update to oreo 8.1..Issues after the updates were flodding in on forums..
    What's ur opinion
  17. G_Marika_Vahtera_NUho
  18. Johnathan Wick
  19. Waveform Modifier
    Marshmallow Apr 21, 2018
    Waveform Modifier , Apr 21, 2018 :
    Who are you calling people?
  20. idkwhoiam322
    Nougat Apr 21, 2018
