617
OxygenOS 5.1.1 OTA for the OnePlus 5 & 5T
Thread Status:
Not open for further replies.
  1. Aeron
    Gingerbread May 17, 2018
    Aeron , May 17, 2018 :
    Yes had the same problem few days ago. I even tried to register to 4G network directly and this went fine but Mobile Data were not availible even though they were enabled. I have changed it to LTE only registered to 4G network directly and no change. Only reboot of phone helped.
    Unfortunately i dont have always access to this phone as my faimly member is using it (i just support).
    Did you submit bug report ?
  2. Rao_Saurabh
    Rao_Saurabh , May 17, 2018 :
    noted... thanks sir..
  3. kasi_kashh
    Cupcake May 18, 2018
    kasi_kashh , May 18, 2018 :
    I am experiencing lag few times in this new update. Please look after this so that it gets corrected in next update.
  4. Chungtd
    Gingerbread May 18, 2018
    Chungtd , May 18, 2018 :
    Not yet.
    It happened to me this morning again.
    If it happens again, I will send them a ticket.
  5. Aeron
    Aeron , May 18, 2018 :
    OK I will do the same. So far it happened only once and even that happened during time when my carrier was changing LTE to Advanced LTE. If it happens again i will post again and submit bug report.
    Chungtd likes this.
  6. E.D.T.H
    Eclair May 18, 2018
    E.D.T.H , May 18, 2018 :
    Is it possible to have volte support on both sim.? Like the nokia 7 did..?
  7. prat_brat
    Froyo May 18, 2018
    prat_brat , May 18, 2018 :
    Hello,
    I see there are a lot of issues/problems with the OS 5.1.1 such as:
    1. Battery Life Degradation.
    2. Slow performance.
    3. Some features removed or not working.
    4. Other general UI or small problems.
    My question, Had OP seen these problems and gave us any feedback on the resolution to these problems. If yes, when? and If No, should we still keep praying or commenting.
    Let me know guys.
    Thanks.
    Oh yeah, I haven't updated to the 5.1.1 still in 5.0.4 better than the latest.
  8. Qwert Luiop
    Froyo May 18, 2018
    Qwert Luiop , May 18, 2018 :
    Comparing 5.0.4 to 5.1.1, I prefer the latter because I have fewer issues with it. You can try clearing cache from storage and recovery, this has been helpful.
  9. G_T_Bennett
    Jelly Bean May 18, 2018
    G_T_Bennett , May 18, 2018 :
    Please note those complaining about 5.1.1 are still a small minority of users. The update works as it should and improves on both Nougat and 5.0.
  10. prat_brat
    Froyo May 18, 2018
    Well, How has it affected you? Has it brought any problems or, it works the same as before.
  11. prat_brat
    Froyo May 18, 2018
    Oh nice, I'm glad. May be, I'll try. Thanks for your response.
  12. G_T_Bennett
    I use it currently with improved speed, approximately 9.5 hours of Screen on time and features working as they should (at least for my everyday use). My battery needs to be charged every 30 hours or so based on usage. You won't hear this as much because those without problems aren't going through forums to express that constantly (except myself and a few others).
    For security purposes, I'd also strongly recommend updating as patches are released with new Operating systems.
    prat_brat likes this.
  13. prat_brat
    Froyo May 18, 2018
    Thank you so much, this is what I've been looking for man.
    If you or someone would have said this earlier.
    Thanks a lot man. Helps a lot man. I guess, I'll update mine soon.
    Thanks Bruv.
    G_T_Bennett likes this.
  14. aaditya007
    aaditya007 , May 18, 2018 :
    what about the battery after updating oneplus 5 to OxyOS 5.1.1 ,
    is it improved? i haven't updated my mob. yet. please suggest.
  15. darkarchon02
    darkarchon02 , May 18, 2018 :
    does this support dual apps like running 2 apps at the same time in a split screen? i hope they add this feature
  16. Qwert Luiop
    Froyo May 18, 2018
    Anytime
  17. Abdul Khadar basha
    haxelmans likes this.
  18. MIHIRJOGANI
    Eclair May 18, 2018
    MIHIRJOGANI , May 18, 2018 :
    I am having issues with my wifi and whatsapp. If my phone is connected to wifi and on full 100%, sometimes messages dont go through or i dont get it after a while.
  19. G_T_Bennett
    Report this in the Bugs section. You are tagging the wrong person.
  20. Mithun Kumar Gumgaonkar
    devanshsadhotra likes this.
