371
OxygenOS 5.1.11 OTA for the OnePlus 6
  1. ssanit
    Eclair Aug 19, 2018
    ssanit , Aug 19, 2018 :
    There are no battery issues with this update, as there were none in the previous updates.
    I suspect that the culprit for such complaints is, in the 99% of cases, either
    - unrealistic expectations (battery life is very good, but the battery capacity is not the best on the market;
    - using apps well known for gobbling battery juice (go to Settings/Battery to see what are the most greedy apps. Try to uninstall them and see how the phone behaves for a couple of days).
    For the remaining 1% of the cases, there is either
    - a software issue (this might be the case, if you started having issues only after a certain software update: in this case you could try to clean the system chache and the apps cache, or making a hard reset, losing all you data);
    - other issues: you'd better get in touch with OnePlus instead of complaining here (it's useless)
    Vladut123, Aks41179 and ade0410 like this.
  2. ade0410
    Ice Cream Sandwich Aug 19, 2018
    ade0410 , Aug 19, 2018 :
    you need to go into security and pin. enter it and there is a tick box underneath that you need to check to remove the tick when entering your pin.
    works fine for me.
    no problems.
    Vladut123 likes this.
  3. G_Kanchan_Sharma_IDGq
    Donut Aug 19, 2018
    G_Kanchan_Sharma_IDGq , Aug 19, 2018 :
    thanks. will try
  4. FaleshC
    KitKat Aug 19, 2018
    FaleshC , Aug 19, 2018 :
    Indeed.
  5. Anubhav1711
    Gingerbread Aug 19, 2018
  6. Anubhav1711
    Anubhav1711 , Aug 19, 2018 :
    I believe that shouldn't be with all Apps. It only happens with Chrome & Instagram. And it's the apps that are at fault as they freeze. You can actually kill those apps when you think your phone has hanged.
  7. C1512271558767
    Cupcake Aug 19, 2018
  8. T1530626694637
    Eclair Aug 19, 2018
  9. István Antal Mező
  10. Musibatt_
  11. chiribauradu
    chiribauradu , Aug 19, 2018 :
    Where is the confirmation for Android Phone beta?
  12. nitishkhullar1187
    Honeycomb Aug 19, 2018
    nitishkhullar1187 , Aug 19, 2018 :
    wifi signal is being shown as Active, under battery stats, even when it was turned off for couple of hours.....
  13. V1532632639734
    Eclair Aug 19, 2018
    V1532632639734 , Aug 19, 2018 :
    do as following.
    go to WiFi settings
    go to scanning setting
    switch off both the options
  14. nitishkhullar1187
  15. shashank7world@g
  16. E380813
    E380813 , Aug 19, 2018 :
    here:
  17. armada_red
    armada_red , Aug 19, 2018 :
    anything on this?
  18. F_Rushabh_Shah_King_mAWR
  19. Enjamul_Haque
    Donut Aug 19, 2018
  20. nairsantho
    Eclair Aug 19, 2018
