371
OxygenOS 5.1.11 OTA for the OnePlus 6
  1. Elaitscha
    Eclair Aug 21, 2018
    Elaitscha , Aug 21, 2018 :
    Wiping cache is not necessary and doesn't affect the system due to the fact that after a new instalation there isnt a old partition left and so nothing to wipe.
    Wiping apps cash will help yeah there you're right. And also the thing for battery calibration (charging to 100% and let it go until 0%) could help to calibrate the device new.
    In my opinion (I do have a OnePlus 6 128/8 Mirror black a6003) the only problems are the devices which is the model a6000 so the Indian one. I also read lots of complains, mostly from Indian users.
    --) before I bought my OnePlus I was afraid of buying it but now on "my" device everything is ok and I don't have problems with heating up or getting the worst battery ever or just having app issues. Still using the 5.1.9 cause I had no problems.
    The only thing every one should keep in mind: Never change a running system if everything is ok (don't update if it's highly recommend).
    Thx
  2. Tulsiram sharma
    Donut Aug 21, 2018
    Vladut123 likes this.
  3. AcmE85
    Ice Cream Sandwich Aug 21, 2018
    AcmE85 , Aug 21, 2018 :
    Now we have to take a closer look and ask if the problem is really the device itself, or if it is actually user error if you know what I mean. Without wanting to offend anybody, Indian users are the most verbal in the forums and always have the most issues with everything. Just saying.
    Sorry guys, but this is a fact.
  4. I1531403925676
    Cupcake Aug 21, 2018
  5. asliyash
    Froyo Aug 21, 2018
    asliyash , Aug 21, 2018 :
    EVERYTHING works fine but it bothers me so much that they still haven't fixed the pocket mode for not unlocking the phone using fingerprint while it's in the pocket. It keeps unlocking or vibrating in the pocket or while on call and I suspect that while it constantly tries to unlock the phone it may also be consuming a bit more battery that is totally a waste.
    I hope they fix it soon in the Pie update.
    Ps: Does anyone have no issues as such for pocket mode? Or does anyone's got any solution or something?
    Vladut123 and AcmE85 like this.
  6. Kytharsis
    Marshmallow Aug 21, 2018
    Kytharsis , Aug 21, 2018 :
    This is by design in 5.1.9 as confirmed by the mod with the Bender avatar (I cannot remember his name). Pocket mode is meant to block screen touches, not fingerprint sensor touches.
    Vladut123 and Deactivated User like this.
  7. SHUBHAMRAJPAL
    Gingerbread Aug 21, 2018
    SHUBHAMRAJPAL , Aug 21, 2018 :
    Try clearing cache and reboot
  8. DeluxeNoone
    DeluxeNoone , Aug 21, 2018 :
    Clear cache via recovery will not do anything on Android 8.1 you will have to clear cache from Settings - Storage & memory and then Cached data.
    MCunha and Vladut123 like this.
  9. Deactivated User
    Aug 21, 2018
  10. S1534528660707
    S1534528660707 , Aug 21, 2018 :
    did they solve that? is it something hey can solve? never thought of it actually....
  11. rsahu6563
    rsahu6563 , Aug 21, 2018 :
    auto hdr is not working after the latest update please fix it when switching to bright light auto hdr been enabled ,the hdr does not enable I have to switch it on manually
  12. Deactivated User
    Aug 21, 2018
  13. Deactivated User
    Aug 21, 2018
  14. ShredMeister
    Honeycomb Aug 21, 2018
    ShredMeister , Aug 21, 2018 :
    Insanely good battery life after this upgrade... thanks OnePlus, keep up the great work you are doing!
    Vladut123 and S1534528660707 like this.
  15. Mange80
    Mange80 , Aug 21, 2018 :
    Maby you should have read the post above yours before posting.
  16. DeluxeNoone
    I hope OxygenOS 5.1.12 will come soon as 5.1.11 did break the camera quality.
    Wondering if Oneplus is checking the Rom before they send it out?
  17. balluxlent
    Eclair Aug 21, 2018
    balluxlent , Aug 21, 2018 :
    hey my OP6's flash light getting on even with wrong touch ,as i configured my device for V gesture but flash light get ON evn with single touch.
  18. Anjoschka
    Froyo Aug 21, 2018
    Vladut123 and ratansuthar00 like this.
  19. Anjoschka
    Froyo Aug 21, 2018
    Anjoschka , Aug 21, 2018 :
  20. asliyash
    Froyo Aug 21, 2018
    obviously pocket mode should be implemented for the fingerprint as well. just imagine the scenario when you're in a call and as you accidentally touch fingerprint sensor (which you obviously can most of the time in calls) the phone will keep on unlocking the screen (which is literally happening). It's even preventing the basic function of proximity sensor while on calls. It was a nice feature to have
