370
OxygenOS 5.1.11 OTA for the OnePlus 6
  1. Abhi131989
    Eclair Aug 27, 2018
    Vladut123 likes this.
  2. mayurchithore
    Eclair Aug 27, 2018
    mayurchithore , Aug 27, 2018 :
    so why do they have the led notification tab in display settings to change the colour of notification led for low battery, charging and full battery.
    If like you said blue led notification means charging rapidly so they shouldn't have put those settings in display.
  3. Artemus.
    Community Hero 2020 Aug 27, 2018
    Artemus. , Aug 27, 2018 :
    I don't know, ask the actual developers.
  4. deasom
    Honeycomb Aug 27, 2018
    deasom , Aug 27, 2018 :
    A Google search?
    yes, blue is reserved for fast charging.
  5. mayurchithore
    Eclair Aug 27, 2018
    so if you don't know then who the hell are you to tell me go sit back down.
    this tab is to share problems we find, so that they can improve. I simply put what I experience with this OS.
    If you are not comfortable with that then get the hell out of here.
  6. Artemus.
    You do realize I gave answers to all your inquiries. The part about "sharing with the class" was in response to your battery woes. It means "post screenshots of your battery stats" which you failed to do.
  7. mayurchithore
    Eclair Aug 27, 2018
    yeah Google assistant is not working for me.
    and yeah if blue is reserved for fast charging so they shouldn't have put those setting in first place.
  8. deasom
    You can choose the color of all the other options, but FAST charging seems to be locked to blue.
    Vladut123 and U1527917758122 like this.
  9. deasom
  10. mayurchithore
    Eclair Aug 27, 2018
    There are so many pictures of battery drain on this forum. if you kindly check before comments you get to know battery drain issue.
  11. Artemus.
    But I'd rather see yours to see what you're doing to drain your battery. ;)
    Vladut123 and Deactivated User like this.
  12. mayurchithore
    Eclair Aug 27, 2018
    in that case they should remove those settings.
  13. mayurchithore
    Eclair Aug 27, 2018
    I don't have it. but I will share with you. rather tag you.
  14. Artemus.
    That's fine.
  15. Hemanth Sagar Reddy
    Cupcake Aug 27, 2018
    Hemanth Sagar Reddy , Aug 27, 2018 :
    I'm having issues with my Bluetooth connection to Car Music system.
    Everytime I get a new notification on mobile the audio output option always switches back to Phone speaker and I have to switch it back to my car manually everytime.
    it is very annoying and troublesome
    so please look into this matter and provide with a solution as soon as possible
  16. Deactivated User
    Aug 27, 2018
    Vladut123 and mayurchithore like this.
  17. mayurchithore
    Eclair Aug 27, 2018
    yeah it could be some bad apps draining my battery.
  18. bittss2
    Froyo Aug 27, 2018
    bittss2 , Aug 27, 2018 :
    No battery drain problem here.. Infact battery is amazing after 5.1.11 attaching screenshots. Getting 3+ hours of SOT in just 47% still half of the juice is remaining. Easily 6+ hours of SOT
  19. TarekHabib
    Donut Aug 27, 2018
    TarekHabib , Aug 27, 2018 :
    Everything gonna be good and given wonderful performance ..
    But .. if is it's possible update like .. OnePlus's own music app .. camera update like .. wide angle ..
    it's will be just damn perfect ..
  20. U1532952418807
    Eclair Aug 27, 2018
    U1532952418807 , Aug 27, 2018 :
    after this update the receiving strength of signal has reduced ...where Zenfone with 645 processor is getting 8.5 Mbps and my op6 is getting nearly 3.2mpbs...
    plz try to fix the signal receiving bug.... hope the next update will be as soon as possible...
    Vladut123 and Jagdish Vijarniya like this.
