370
OxygenOS 5.1.11 OTA for the OnePlus 6
  1. deasom
    Honeycomb Sep 6, 2018
    deasom , Sep 6, 2018 :
    nastasedan
    How so? Why do we have the option to set other color while charging then? Can you please explain?
    Anyone can recommend a method to lock the screen without pressing the Power button? I use navigation gestures. Thank you!​
    The blue light is designated for FAST charging. You can't change that. You can change the color for regular charging.
    Double tap the screen is what most use. it's enabled in settings.
    edit......launcher settings
    Vladut123 and nastasedan like this.
  2. nastasedan
    Froyo Sep 6, 2018
    nastasedan , Sep 6, 2018 :
    Thank you very much, I didn't know that!
    All sorted out!
    Vladut123 likes this.
  3. nastasedan
    Froyo Sep 6, 2018
    Is there a way to disable the vibration when you double tap the screen to wake the phone?
  4. Artemus.
    Community Hero 2020 Sep 6, 2018
    Artemus. , Sep 6, 2018 :
    Nope.
    Vladut123, Aks41179 and nastasedan like this.
  5. bittss2
    Froyo Sep 6, 2018
    bittss2 , Sep 6, 2018 :
    I am facing the same issue. My 1st sim is jio and 2nd is airtel.
    You can look at network in the screenshot. Its poor and consumes hell lot of battery.
    Network Connectivity is very poor on OnePlus 6. Hope they will improve in next update.
  6. Artemus.
    It's not the phone, it's Airtel. According to a lot of cupcakes, their service sucks.
  7. Vinay_NS
    Gingerbread Sep 6, 2018
    Vinay_NS , Sep 6, 2018 :
    Kytharsis
    It's not the phone, it's Airtel. According to a lot of cupcakes, their service sucks.​
    ok kitkat user.. i hope you are right..
  8. Vinay_NS
    ok.. but i am pretty much sure that signal bar doesn't indicate whether network is good or bad.. i think it's just for representation purpose..
  9. K1536252879532
    Cupcake Sep 6, 2018
    K1536252879532 , Sep 6, 2018 :
    Suddenly my OnePlus camera is unable to take clear picture, the colour scheme got changed.. there was earlier red wall paper which. changed to the darker one which is not good
  10. D1517844581455
    D1517844581455 , Sep 6, 2018 :
    looks like this has been done intensionally!!
  11. aksiraj
    Donut Sep 6, 2018
    aksiraj , Sep 6, 2018 :
    hello 1+6 team..... I've one suggestion ppz update auto cut-off when battery is reached ...BCS i thought u updated the last time.....but u didn't....ppz give as next time....we need it.,...... anyway gud job team
  12. ade0410
    Ice Cream Sandwich Sep 6, 2018
    ade0410 , Sep 6, 2018 :
    if you actually word posts coherently then maybe they'd understand. I cannot fathom how you get to this point where you think it's acceptable to talk like this.
    really, really bizarre.
  13. R1527406085175
    Cupcake Sep 6, 2018
    Vladut123 and kgerolio like this.
  14. Deactivated User
    Sep 6, 2018
  15. Shavir_Afroz
    Froyo Sep 6, 2018
    Shavir_Afroz , Sep 6, 2018 :
    blue color comes up only when dash charging is active, i.e you are using dash charger and dash cable for charging.
    your custom colors will come up only when you will use anything other than dash charger to charge your device up.
    use any 5Volts 2Amps charger of any company and you will see those custom colors you set
  16. HasanKacan
    Cupcake Sep 6, 2018
    HasanKacan , Sep 6, 2018 :
    In Beta P version, the main screen crashes when you load the 'contact' widget. Does this have a solution?
  17. HasanKacan
    Cupcake Sep 6, 2018
    Why does the shortcuts become black when I make a dark color user wallpaper instead of Stock wallpaper in Beta P version?
  18. Artemus.
    Use. The. Beta. Thread.
  19. wkyaw23
    Cupcake Sep 6, 2018
  20. UnicornKaz
    Ice Cream Sandwich Sep 7, 2018
