270
OxygenOS 5.1.2 OTA for the OnePlus 5 & 5T
  1. Kytharsis
    Marshmallow May 27, 2018
    Kytharsis , May 27, 2018 :
    Everyone complains yes but 99% of them post no evidence of the camera being bad. And the ones who do usually consists of bad lighting or angle issues.
    W1519712713652 likes this.
  2. Aziz_Amin_Oneplus
    Jelly Bean May 27, 2018
    Aziz_Amin_Oneplus , May 27, 2018 :
    Only Selfie Camera is coming up with drainy photos, only this is the problem we all 5t users are facing please OnePlus Team fix this as soon as possible.
  3. Kytharsis
    Oxygen Updater doesn't require root...? It helps keep root yeah but doesn't require it. I don't think.
  4. Lorko64
    Cupcake May 27, 2018
    Lorko64 , May 27, 2018 :
    why ?
  5. arvindsk143
    Froyo May 27, 2018
    arvindsk143 , May 27, 2018 :
    see evidence.. check on face... pixels damaged and pic not clear..
  6. danishdaycare
    Ice Cream Sandwich May 27, 2018
    danishdaycare , May 27, 2018 :
    So pixels and photos today are bad and tomorrow they be worse. That's impossible. Or you have a fawlty device and should return it with warranty.
  7. Herbert_Lagos
    Herbert_Lagos , May 27, 2018 :
    Reported because of insults
  8. Charu Nandan Reddy
  9. axedonwood
    Froyo May 27, 2018
    axedonwood , May 27, 2018 :
    Hi,
    well I've rooted my op5 so how am I suppose to update?
    it gives me a pop up stating the device would be unrooted once done.
    is it safe and will it lock the bootloader?
  10. Kytharsis
    It's safe but you'll have to reflash Magisk to regain root again. And no, the bootloader will not relock.
    Use Oxygen Updater and do automatic installation. It'll allow you to flash Magisk after installation automatically if you choose to.
    axedonwood and kaushaldevy like this.
  11. axedonwood
    Froyo May 27, 2018
    thanks mate.
    cheers
    Kytharsis likes this.
  12. hashmune
    Froyo May 27, 2018
    hashmune , May 27, 2018 :
    Thanks OnePlus team for continuous security patches & fixing notification center padding [e]1f603[/e]
    Cheers!
  13. L1527449508520
  14. vasueza
    Gingerbread May 27, 2018
  15. kaushaldevy
    KitKat May 27, 2018
    kaushaldevy , May 27, 2018 :
    yeap. It is normal
  16. drszali
    drszali , May 27, 2018 :
    What is the camera version?
  17. kaushaldevy
    KitKat May 27, 2018
    drszali likes this.
  18. kaushaldevy
    KitKat May 27, 2018
    Best SOT I ever got. A normal day usage for 6h 22m SOT and still 50% remaining...!!! Either this is some sort of a voodoo magic or my battery calibration has gone nuts (which I doubt). Happened after 5.1.2 On 5T 8GB
    Paul_W_, f0li0, hashmune and 2 others like this.
  19. P1512569276852
  20. Lloydxiii1210
    Lloydxiii1210 , May 27, 2018 :
    hi am facing a issue with auto brightness on my 5t. Have this issue with the device from long time. some times the auto brightness works fine. and most of the time have to turn it off and on. It is getting a little annoying. Is any one else facing a similar issue.
