271
OxygenOS 5.1.2 OTA for the OnePlus 5 & 5T
  1. devanshsadhotra
    Gingerbread May 28, 2018
    devanshsadhotra , May 28, 2018 :
    since update my phone has freezed 2 times and I had to force restart it , by keeping volume down and power key pressed for a minute or 2
  2. devanshsadhotra
    it's deprecated now !! please use surf easy
  3. Martijn2111
    Honeycomb May 28, 2018
  4. devanshsadhotra
    surf easy
  5. mark.aranha
    Donut May 28, 2018
    mark.aranha , May 28, 2018 :
    I have a 5T, and I'm still on Oxygen 5.0.3
    Battery life is great and performance is fine. There's just one major bug...
    When I activate Bluetooth and try and pair it with a car stereo or Bluetooth speaker, sometimes the phone hangs. It just goes dead, unresponsive. The music that was playing continues to play and the only thing I can do is hold down the power button and restart.
    Now if there was a bug fix for THAT, I would gladly update the ROM.
  6. MirAamirHamid
    Eclair May 28, 2018
    MirAamirHamid , May 28, 2018 :
    Has anyone updated their device to the latest Oxygen OS 5.1.2 ?
    Any bugs guys?? Battery issues, or other issues any?
    G_Mr_.... and Beatsx like this.
  7. Jayosen671
    Eclair May 28, 2018
  8. u2knockout
    Eclair May 28, 2018
    u2knockout , May 28, 2018 :
    is d update available for 5t..??why I am unable to get it even after using melon VPN and surf easy VPN..?? I changed to Canada and Germany location..
  9. u2knockout
    Eclair May 28, 2018
  10. u2knockout
    Eclair May 28, 2018
  11. ɢноѕтΘпе
    Nougat May 28, 2018
    ɢноѕтΘпе , May 28, 2018 :
    Works fine for me.
  12. G_Noel_Scerri_MZRk
    Donut May 28, 2018
  13. devanshsadhotra
    yes it's available for 5T,
  14. Nick 59
    Marshmallow May 28, 2018
    Herbert_Lagos and borft like this.
  15. V.floo
    Shery4life and mark.aranha like this.
  16. V.floo
    V.floo , May 28, 2018 :
    Works great.
    Some bugs were solved.
    And aslo battery life seems to be longer compared to 5.1.1.
  17. Rahul_Singh_Kshatri
    Rahul_Singh_Kshatri , May 28, 2018 :
    can anyone tell me about thing below the alarm volume I don't understand why is that available and how to disable that
  18. kaushaldevy
    KitKat May 28, 2018
    kaushaldevy , May 28, 2018 :
    Rahul_Singh_Kshatri
    can anyone tell me about thing below the alarm volume I don't understand why is that available and how to disable that​
    press both volume up and down buttons for 3 seconds to disable it. It is TalkBack, an Accessibility utility. Can be found at Settings> Advanced> Accessibility> TalkBack => off
    Rahul_Singh_Kshatri likes this.
  19. Rahul_Singh_Kshatri
    what is that indicated for any idea ?
  20. Shriresh
    Eclair May 28, 2018
    Shriresh , May 28, 2018 :
    After upgrading my Oneplus 5t to 5.1.2,double tap to lock is not working. Is there any setting to be enabled?
