271
OxygenOS 5.1.2 OTA for the OnePlus 5 & 5T
  1. kaushaldevy
    KitKat May 28, 2018
    kaushaldevy , May 28, 2018 :
    Same thing, just rebranded due to trademark issues
    D1523707387331 likes this.
  2. Meetpanchal
    Gingerbread May 28, 2018
  3. D1523707387331
    Cupcake May 28, 2018
  4. kaushaldevy
    KitKat May 28, 2018
  5. ankkeet_99
  6. ankkeet_99
    ankkeet_99 , May 28, 2018 :
    Connect to Germany it'll work.
  7. ankkeet_99
    Use flash VPN from playstore & connect to Germany
  8. ankkeet_99
    Check in the battery stats & disable/uninstall the apps that are draining battery.
    Meetpanchal likes this.
  9. V.floo
    V.floo , May 28, 2018 :
    It is more 'bug free' a full rom instalation ;) .
    So maibe this way we will not see 1001 uselessl threads (about non-sense small bugs) created after an update.
  10. Pamidimukkula
    Donut May 28, 2018
    Pamidimukkula , May 28, 2018 :
    I didn't get new update it could take time on this new feature. If any body can tell me that it could take some time for some members on 5T. please help me on thia
  11. kaushaldevy
    KitKat May 28, 2018
    Did you try to use a VPN
  12. Chirostavros
    Chirostavros , May 28, 2018 :
    No one is pleased with any update. There is no bugless update guys. There will always be bugs minor or major..!
  13. Ved Rai
    Ved Rai , May 28, 2018 :
    I am facing a problem with my one plus 3t device that is whenever I receive a call the phone screen does not glow(or respond just remains black ) I have to manually press the phone lock button to unlock the phone then try to answer the call pls suggest a solution for the same. I don't see any fix for my issue.
  14. [email protected]
    Honeycomb May 28, 2018
    [email protected] , May 28, 2018 :
    wrong thread buddy
    AdikartaDasa, macemoneta and Artemus like this.
  15. Ved Rai
    I am facing a problem with my one plus 3t device that is whenever I receive a call the phone screen does not glow(or respond just remains black ) I have to manually press the phone lock button to unlock the phone then try to answer the call pls suggest a solution for the same. I don't see any update regarding this.
  16. [email protected]
    Post in OnePlus 3/3t section
  17. Ved Rai
  18. kaushaldevy
    KitKat May 28, 2018
    Is your proximity sensor covered...?
    By a screen protector, grease or something
  19. Ved Rai
    No, this is nothing like that. I an not using any screen protector.
  20. Pratim_Das_Gupta
    Froyo May 28, 2018
