271
OxygenOS 5.1.2 OTA for the OnePlus 5 & 5T
  1. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator May 28, 2018
    Artemus , May 28, 2018 :
    Soon.™ Either use a VPN to spoof your location or wait.
  2. kaushaldevy
    KitKat May 28, 2018
    kaushaldevy , May 28, 2018 :
    Just in case, try to clean the area where proximity sensor is...
    In which version of OOS are you in...?
  3. Ved Rai
    Cupcake May 28, 2018
    Ved Rai , May 28, 2018 :
  4. Ved Rai
  5. kaushaldevy
    KitKat May 28, 2018
    @Ved Rai Try the 5.1.2 update... It is relatively a better one in my experience. Also, is this happens when you are in Do Not Disturb mode...?
  6. Ved Rai
    Yes, this happened in Do Not Disturb mode as well
  7. kaushaldevy
    KitKat May 28, 2018
    Try to use silent mode with vibrate on and check whether the issue persists...
  8. Ved Rai
    It's same for vibrate mode as well
  9. David500
    David500 , May 28, 2018 :
    This was a fantastic update. It made everything snappy again ... really fast. I most definitely recommend updating. Thank you Oneplus!
  10. G_T_Bennett
    Jelly Bean May 28, 2018
    G_T_Bennett , May 28, 2018 :
    Check phone apk settings, something must have been turned off in terms of settings.
  11. Ved Rai
    Can you please be more specific. I have checked everything from my end .
  12. kaushaldevy
    KitKat May 28, 2018
    Settings>Apps> Application list> search for phone> permissions
  13. Pamidimukkula
    Donut May 28, 2018
    Pamidimukkula , May 28, 2018 :
    hi!
    I appreciate for your reply can I know what I have to be done on VPN
  14. Ved Rai
  15. kaushaldevy
    KitKat May 28, 2018
    Follow these guidelines
    * Download and install Turbo VPN from play store
    * Then, open the app and connect to the Canada/Germany region within the app.
    * Go to settings>System Update. It'll automatically check for updates
    If not tap Check for updates
    * Once the update appears and you can disconnect the VPN and use normal wifi/data connection.
    * OOS 5.1.2 is a 1.6 GB size upgrade
  16. Pamidimukkula
    Donut May 28, 2018
    sure thank you
  17. kaushaldevy
    KitKat May 28, 2018
    IMO, One of the best things you can do right now is to update to 5.1.2 and check whether the issue is still there...
  18. Ved Rai
    I can't see the new update for phone .From where I can get. Please help me.
  19. kaushaldevy
    KitKat May 28, 2018
    Follow the following instructions to download it using VPN
    * Then, open the app and connect to the Germany/Canada region within the app.
  20. reojo
    Froyo May 28, 2018
