270
OxygenOS 5.1.2 OTA for the OnePlus 5 & 5T
  1. HongKong User
    Honeycomb May 29, 2018
    HongKong User , May 29, 2018 :
    where are you ? which zone are you in ?
  2. krito007
    Cupcake May 29, 2018
    krito007 , May 29, 2018 :
    wow lots of improvement after the update.battery stability went back to normal
    I was confused whether to update or not.
    now I'm happy with it
  3. krito007
    yes.im from India I've got the update
  4. patilpr
    Eclair May 29, 2018
    patilpr , May 29, 2018 :
    In India
  5. vovowong
    Gingerbread May 29, 2018
  6. Antonyhyson
    Eclair May 29, 2018
  7. G_SUMANTH_PM_zUml
  8. R1512322128771
    Donut May 29, 2018
    R1512322128771 , May 29, 2018 :
    I connected to Germany on turbo VPN and it worked. thanks ankit
  9. E1519569148540
    Donut May 29, 2018
    E1519569148540 , May 29, 2018 :
    I'm still running 5.0.4 and the 'places' feature in the gallery app is already available why are they adding it?
  10. san94fbr
    Shidharth Jayakannan likes this.
  11. san94fbr
    san94fbr , May 29, 2018 :
    when did you received and how ?
  12. Shidharth Jayakannan
    Shidharth Jayakannan , May 29, 2018 :
    If you need faster you could use tunnel bear VPN app from playstore and set Canada VPN and Check For Updates
  13. Luisdemadrid
    Donut May 29, 2018
  14. Shriyash_Maindarkar_Vc
    Froyo May 29, 2018
  15. G_GuruPrasad_Subramanian
    Eclair May 29, 2018
    G_GuruPrasad_Subramanian , May 29, 2018 :
    oneplus 5 - volte icon disappeared from the notification post the update. Is anyone facing the same issue? I am using Airtel network from Chennai, India.
  16. G_GuruPrasad_Subramanian
    Eclair May 29, 2018
  17. O1527568275552
    Rahul_Singh_Kshatri likes this.
  18. Ali2112c
    Eclair May 29, 2018
    Ali2112c , May 29, 2018 :
    turbo VPN also works. select Canada and as if by magic, the update appears [e]1f601[/e]
  19. CarlosRod35
    Eclair May 29, 2018
    CarlosRod35 , May 29, 2018 :
    No tendrás la versión Beta?
  20. Rahul_Singh_Kshatri
    prat_brat likes this.
