271
OxygenOS 5.1.2 OTA for the OnePlus 5 & 5T
  1. JYanz
    Gingerbread Jun 3, 2018
  2. Rohan.M
    Rohan.M , Jun 3, 2018 :
    I was also facing the rapid battery drain issue after the update, however I have cleared cache from recovery & now there is no issue.
  3. G_Vishval_Patel_nyim
    Cupcake Jun 3, 2018
  4. G_Vishval_Patel_nyim
    Cupcake Jun 3, 2018
    G_Vishval_Patel_nyim , Jun 3, 2018 :
    How.??
  5. Rohan.M
    Power off your device. Then press & hold power + volume down button until you see one plus logo, then release the buttons. You will enter in recovery mode shortly. after that go to - wipe data & cache - only select cache & then you will get reboot option.
  6. G_Vishval_Patel_nyim
    Cupcake Jun 3, 2018
    What about data.???
    Erased or safe.??
  7. Rohan.M
    As I said, only select "Cache option while wiping, no data loss. But if you mess then it's your fault.
  8. G_Vishval_Patel_nyim
    Cupcake Jun 3, 2018
    So what will happed if i select cache option ??
    All app data will be erased and internal data will be safe
    Right.??
  9. Rohan.M
    Data and cache are different things bhai. Cache is like temp files. There will be no app data or personal data loss.
  10. vinz_uk80
    vinz_uk80 , Jun 3, 2018 :
    Very happy with the latest 5.1.2 build (rooted inside).
    Really smooth, very stable, great battery life as always.
    Together with Gcam, the OP5 is still a Great phone.
    IsseiSenpai likes this.
  11. vipul_sethi
    Ice Cream Sandwich Jun 3, 2018
  12. Aravimd
    Eclair Jun 3, 2018
    vipul_sethi likes this.
  13. Aziz_Amin_Oneplus
    Jelly Bean Jun 3, 2018
  14. vipul_sethi
    vipul_sethi , Jun 3, 2018 :
    before update i had like 4 hrs screen on time now it is around 6 hrs, that is good enough for me mate
    Aravimd likes this.
  15. Kunduabhishek
    Cupcake Jun 3, 2018
    Kunduabhishek , Jun 3, 2018 :
    why not ? nokia 7 plus has done it via ota. volte support is a software upgrade thing in a supported hardware. sd 835 is already supported.
  16. Ih.nihal
    Eclair Jun 3, 2018
    Ih.nihal , Jun 3, 2018 :
    "Modified the same option with latest OTA update". anyone got always on display feature? what did he actually meant?
  17. Sanyatoneplus
  18. Kunduabhishek
    Cupcake Jun 3, 2018
    sd 660 & kirin 970 support dual volte. but sd 835 doesnt support it. strange. then sd 845 should support it.
  19. rushup
    Froyo Jun 3, 2018
    rushup , Jun 3, 2018 :
    Unable to pull notification/quick settings panel from full screen app, games, videos. Any help guys?
  20. rushup
    Froyo Jun 3, 2018
    Its in Launchers 'Home settings'. Long press on home screen to access.
