359
OxygenOS 5.1.4 OTA for the OnePlus 5 & 5T
  1. G_T_Bennett
    Jelly Bean Aug 2, 2018
    G_T_Bennett , Aug 2, 2018 :
    The fix for this has already been posted numerous times in this thread.
    No one knows when it'll be expected.
  2. Manas_Mishra_1989
    Ice Cream Sandwich Aug 2, 2018
    Manas_Mishra_1989 , Aug 2, 2018 :
    Because its complete build not an incremental update.
  3. Manas_Mishra_1989
    Did u clear cache from recovery?
  4. Christopher@
    Donut Aug 2, 2018
    Christopher@ , Aug 2, 2018 :
    Please I need help!!
    After installing the last OxygenOS 5.1.4, the battery drain very quickly.
    I made maximal 100% charge just this morning, after 5hours i am 20%.
    That was not like that before this updating. I'm using my Oneplus 5T just for 4months.
  5. marcusskyfall
    marcusskyfall , Aug 2, 2018 :
    How many charges have you put through it since you upgraded? Needs at least 3 charge/discharge cycles before it becomes improved.
  6. Chiran_OP5
    Honeycomb Aug 2, 2018
    Chiran_OP5 , Aug 2, 2018 :
    Could you please point me to that post in this thread? many thanks
  7. 2pints
    2pints , Aug 2, 2018 :
    Would be helpful if you could advise others, I assume you mean wipe Cache from recovery.
    reboot to recovery, select wipe, select wipe cache.
    If it doesnt already happen a Cache wipe should take place during the update process, as booting into recovery is not something an average end user should be expected to do
    ouaille13320 likes this.
  8. Aziz_Amin_Oneplus
    Aziz_Amin_Oneplus , Aug 2, 2018 :
    Ok here you guys Clear cache from storage setting first, then shutdown your mobile and then hold the power button and press volume down button, type your password or lock code, select english, you will have wipe cache option go there and wipe cache only reboot and your done, but be aware you have to do 5 to 6 cycles in order for your battery to get sustain, it should be charging to 100% and going down to 1% too after that you will get the good battery result.
  9. F_Richie_Sk_agHO
    Eclair Aug 2, 2018
  10. Aziz_Amin_Oneplus
    It is improve a little and in next update before Android P it will eventually be done more.
  11. bon_truong
    Froyo Aug 2, 2018
    bon_truong , Aug 2, 2018 :
    Sorry to hear that!
    After the update to 5.1.4, I have not experienced any problem with the battery draining fast...
    The update has battery optimization. In addition, if you turn on the battery saving mode, it will last even longer!
  12. R1533239541222
    Cupcake Aug 2, 2018
  13. Aziz_Amin_Oneplus
    It all depends on your usage, this phone can easily give you 1 day and more with 7 hours of SOT which even more than 3300 Mobiles can't give because of it's software so to all users be happy and enjoy the new udpates and your 5t mobile.
  14. Christopher@
    Donut Aug 2, 2018
  15. I1517937457829
    Cupcake Aug 2, 2018
    I1517937457829 , Aug 2, 2018 :
    casting YouTube on TV not working after update. YouTube logo hangs then kicks out. I've tried with a Chromecast stock and also aomy Bravia with Android TV cast built in
  16. Bettina Svane Hansen
    Cupcake Aug 2, 2018
  17. Bettina Svane Hansen
    Cupcake Aug 2, 2018
    Bettina Svane Hansen , Aug 2, 2018 :
    Clearing the cache in recovery worked, so now it seems to be back to normal :)
  18. I1511825439723
    Eclair Aug 2, 2018
  19. S1533223292243
    Cupcake Aug 3, 2018
    S1533223292243 , Aug 3, 2018 :
    my camera is not working properlly.nd vedio call is also not working also say update your call satting
  20. T1511940147666
    Eclair Aug 3, 2018
    T1511940147666 , Aug 3, 2018 :
    Battery draining fast after this update... I never neded to carry my charger but now i need to carry one with me ..
    Please fix the bug....
