359
OxygenOS 5.1.4 OTA for the OnePlus 5 & 5T
  1. G_T_Bennett
    Jelly Bean Aug 3, 2018
    G_T_Bennett , Aug 3, 2018 :
    Do you want me to tell you how?
  2. T1511940147666
    Eclair Aug 3, 2018
  3. G_T_Bennett
    1. Let phone drain to 0%
    2. Recharge to 100% (Device off)
    3. Enter Recovery mode (Power + Volume Down while phone is off).
    4. English - Wipe data and cache - Wipe Cache - Reboot
    5. Use phone normally and report back at ~15%.
  4. T1511940147666
    Eclair Aug 3, 2018
  5. sachin1947
    Donut Aug 3, 2018
  6. Kytharsis
    Marshmallow Aug 3, 2018
    Kytharsis , Aug 3, 2018 :
    Oxygen Updater.
  7. sachin1947
    Donut Aug 3, 2018
    sachin1947 , Aug 3, 2018 :
    yesvi downloaded that, but its asking to select some root folder to keep the root. but what folder is it? and what does the folder contain?
  8. Kytharsis
    Point that folder to the Magisk ZIP file.
  9. sachin1947
    Donut Aug 3, 2018
    oh ok. only magisk apk or any other too?
  10. Kytharsis
    Sorry, I meant to say Magisk ZIP file, not APK. It'll be labeled Magisk_16.0.zip, most likely in the Downloads folder.
  11. sachin1947
    Donut Aug 3, 2018
    is that it?
  12. Kytharsis
  13. Manas_Mishra_1989
    Ice Cream Sandwich Aug 3, 2018
    Manas_Mishra_1989 , Aug 3, 2018 :
    Did you clear cache from recovery after update? others reported the same issue and the solution worked
  14. T1511940147666
    Eclair Aug 3, 2018
    T1511940147666 , Aug 3, 2018 :
    Hey tried the wipe cache method.. Will only know in some time if it worked.. Thanks anyways
  15. T1511940147666
    Eclair Aug 3, 2018
    Hey Hi. Thanks for the help tried the cleaning cache method.. Will only come to know in some time..
    G_T_Bennett likes this.
  16. A1531638631445
    Cupcake Aug 3, 2018
    A1531638631445 , Aug 3, 2018 :
    can anyone help me how the sleep mode works in op5 with update. i have updated the new os but there is no such sleep mode seen in battery (which they had mentioned)
  17. Kytharsis
    Battery > Battery optimization > three dots > Advanced optimization > Sleep standby optimization.
    **Corrected**
  18. eryza
    Cupcake Aug 3, 2018
    eryza , Aug 3, 2018 :
    why does camera version is not the same on everyone who update to OOS 5.1.4?
  19. F1508213523088
    Cupcake Aug 3, 2018
    F1508213523088 , Aug 3, 2018 :
    Battery is draining rapidly after the latest update. Even when phone was idle/stand by over night. Hoping to get fix soon One Plus team.
    V1533271071359 likes this.
  20. sethisidd
    sethisidd , Aug 3, 2018 :
    I have been using the update since last few days and not facing any battery related issues.
    Make sure you clear the cache after any big update and give it a day or 2 to settle down. If you get battery issues even after that, raise an issues at https://forums.oneplus.com/forums/oneplus-5t-support/
