359
OxygenOS 5.1.4 OTA for the OnePlus 5 & 5T
  1. Waveform Modifier
    Marshmallow Aug 3, 2018
    Waveform Modifier , Aug 3, 2018 :
    Welcome to the community. There is no OnePlus Staff here in these parts and only community users is here and only community users is here. As these forums has rules, please find the links below and try your best to follow it (eg. use search).
    Rule of thumb: Whenever posting about battery issue, you need to provide screenshots of your battery history and etc. to prove your case and let us see what the issue is. Ideally, take your screenshot at the end of your usage cycle. (Do not upload via the Community app.) It is also your responsibility to troubleshoot your own issues; users here may suggest fixes but ultimately it is your responsibility.
    Also look through here.
    (https://forums.oneplus.com/threads/...ating-tips-how-to-improve-battery-life.556988)
    (https://forums.oneplus.com/threads/...your-stats-how-to-improve-battery-life.681970)
    In the meantime, use it as usual and keep an eye on what app is wakelocking your phone.
    https://www.themobileindian.com/how-to/how-to-fix-android-os-and-android-system-battery-drain-18698
    Forum rules below for your reference.
    https://forums.oneplus.com/threads/oneplus-forum-guide-for-cupcakes.804637
    https://forums.oneplus.com/threads/checklist-before-posting-a-new-thread.104690
  2. dennisnp
    Froyo Aug 3, 2018
    dennisnp , Aug 3, 2018 :
    Well. Google maps is now believing it is offline when checking poi:s when phone actually is online. But I can use directions and update my offline maps.
  3. Manas_Mishra_1989
    Ice Cream Sandwich Aug 3, 2018
    Manas_Mishra_1989 , Aug 3, 2018 :
    Go to advanced settings under battery optimizations then you will find it
  4. babnik80
    Froyo Aug 3, 2018
    babnik80 , Aug 3, 2018 :
    i've just updated my op5 to 5.1.4 via ota, and i checked my camera version and shows 2.8.11. Is that right? Because i had asked in the forum and i was said another version. 2.5.34 i think. Any help here? Thanks.
  5. SohamMallick
    Eclair Aug 3, 2018
  6. pawanispc
    Eclair Aug 3, 2018
    pawanispc , Aug 3, 2018 :
    Camera version in 5.1.4 is 2.5.34.
    I believe you might have installed the updated camera apk which has google lens integrated.
  7. babnik80
    Froyo Aug 3, 2018
    yes i've installed the camera from apkmirror i think. is there any way to get to 2.5.34;
    thanks for the answer.
  8. Z1533275194501
    Cupcake Aug 3, 2018
    SohamMallick likes this.
  9. satyajeets03
    Eclair Aug 3, 2018
  10. Y1511993274888
    Cupcake Aug 3, 2018
    Y1511993274888 , Aug 3, 2018 :
    My OnePlus 5T was purchased less than a year ago on November 19th, 2017. Before updating to Oxygen OS 3 days ago version 5.1.4 I used to average 5.5-6.5 hours of screen on time. After updating I don't get more than 3 hours of screen on time. This is absolutely ridiculous. I don't know if this is OnePlus' play at getting consumers to buy their new products by reducing the life cycle of the older ones or just a simple error in the software. They need to patch this asap.
  11. pawanispc
    Eclair Aug 3, 2018
    Yes! Just uninstall the camera updates. Goto Setting > Apps > Camera. You will see 3 dots at the top right corner. Tap on it to uninstall updates.
    babnik80 likes this.
  12. babnik80
    Froyo Aug 3, 2018
  13. CosmoKramer70
    Jelly Bean Aug 3, 2018
  14. W1533104499222
    Cupcake Aug 3, 2018
    W1533104499222 , Aug 3, 2018 :
    settings-battery-battery optimization - options : -advanced settings-select sleep waiting optimization.
  15. CosmoKramer70
    SohamMallick and Z1533275194501 like this.
  16. anishnair1010
    Eclair Aug 3, 2018
    anishnair1010 , Aug 3, 2018 :
    disastrous experience with the battery draining even when not used ....already 70 % within 5.5hours..... it's killing the battery ...pls work to patch it up !!
  17. ravi7yadav
    Cupcake Aug 3, 2018
    ravi7yadav , Aug 3, 2018 :
    after One plus 5 update to Oxygen 5.1.4 my face lock is not working...plz help me with that
  18. anishnair1010
    Eclair Aug 3, 2018
    5.1.4 has struck the battery like a cancer ....sucking out a full charged battery in less than 7hrs after it's charge ..!!!!!!
  19. pawanispc
    Eclair Aug 3, 2018
    Did you get any specific error message?
  20. Y1511993274888
    Cupcake Aug 3, 2018
    already done this. making it worse
