359
OxygenOS 5.1.4 OTA for the OnePlus 5 & 5T
  1. gurpalsingh501
    Donut Aug 11, 2018
  2. ogen7uya
    Cupcake Aug 11, 2018
    ogen7uya , Aug 11, 2018 :
    Since updating my OP5 to OxygenOS 5.1.4 last week, I have had several days where the battery drains from 100% to 0% during a work day (~10 hours) with very little use of the phone. Normally I'd have about 80% left of the battery when coming back home, now a few times the phone has actually run empty and shut down before I'm back home. Battery statistics show most of the battery has been spent in "Android OS". There have also been "normal" days after the update, when the battery consumption stays at the regular ~20% with light use.
    This never happened on the previous OS version and I haven't changed settings or installed apps since the update, so my gut feeling is this has something to do with this update.
    T1534173487855 likes this.
  3. G_David_Sidrak_rYck
    Honeycomb Aug 11, 2018
  4. sachkharb
    Ice Cream Sandwich Aug 11, 2018
    sachkharb , Aug 11, 2018 :
    anybody explain 'Sleep Standby Optimization' plzzzzzzzzzzz... how it works and does it only close wifi/data or entire network?
  5. ShaviSuri
    Froyo Aug 11, 2018
  6. Lal1995Roshan
    Gingerbread Aug 11, 2018
    Lal1995Roshan , Aug 11, 2018 :
    Today i came to know that my 5t's speaker mode is not functioning while on call. There is no problem with the hardware as while playing music those works perfectly. This happened after the latest Oxygen OS 5.1.4 update . Already tried wiping cache from recovery and rebooting. Does anyone else face this problem?
  7. vivektrivedi_07
    Froyo Aug 11, 2018
    vivektrivedi_07 , Aug 11, 2018 :
    portrait mode needs more accuracy...below is the photo I clicked after update...
    in 1st pic see the space between arms and body, skipped in portrait...2nd pic was clicked in indoor light, its grainy and dull compare to day pic
  8. Trevor.Hawkes
    Trevor.Hawkes , Aug 11, 2018 :
    If you haven't done any of the following since you updated you should work through the list. After each step check for a time to see if your battery problem has gone.
    - Turn off the phone then restart it.
    - Press and hold the power on button. Hold it till the screen goes blank and you feel the phone vibrate in restart.
    - Go into recovery, select "English" then select "Wipe Data and Cache", then select "Wipe Cache", then select "Yes". Reboot the phone. Do not select to wipe Data.
    If there is still no improvement move onto the big one.
    - Make backups of everything you don't want to lose if not already saved. Select Settings, then Backup and Reset, then Factory reset. An alternative is to go back into recovery and wipe cache and Data.
    If any or all of this cures your battery problem it wasn't caused by the update but it was an app cache or system cache that was screwed in some way during the update.
    ouaille13320 likes this.
  9. marcusskyfall
    Jelly Bean Aug 11, 2018
    marcusskyfall , Aug 11, 2018 :
    Why do you need it? I'm only asking out of curiosity :)
    Mr_Cyrox likes this.
  10. Aziz_Amin_Oneplus
    Aziz_Amin_Oneplus , Aug 11, 2018 :
    It is only good when the phone is idle or when you are sleeping, you will receive all notification and your WiFi and mobile data which is on will be untouch, it will only optimize the battery with your notification to get less battery drain and if you have not enable it then your battery will drain just as it did before.
    sachkharb likes this.
  11. sachkharb
    Ice Cream Sandwich Aug 12, 2018
    sachkharb , Aug 12, 2018 :
    so you are trying to say that there is slightly improvement in standby optimization using this mechanism ???
  12. Sunil Sharma
    Donut Aug 12, 2018
  13. Lal1995Roshan
    Gingerbread Aug 12, 2018
    Lal1995Roshan , Aug 12, 2018 :
    Today i came to know that my 5t's speaker mode is not functioning while on call. There is no problem with the hardware as while playing music those works perfectly. This happened after the latest Oxygen OS 5.1.4 update . Already tried wiping cache from recovery and rebooting. Does anyone else face this problem?.... please respond friends
  14. Zaphodrocks
    Zaphodrocks , Aug 12, 2018 :
    I don't have this issue. It's working normally for me.
  15. cabrera_gc
    Cupcake Aug 12, 2018
  16. Aziz_Amin_Oneplus
    Jelly Bean Aug 12, 2018
    Aziz_Amin_Oneplus , Aug 12, 2018 :
    Yes while on sleep and phone idle.
  17. MJ_Vikram
    KitKat Aug 12, 2018
    MJ_Vikram , Aug 12, 2018 :
    whats special with Xiaomi ?
  18. marko mob5
    Froyo Aug 12, 2018
  19. cabrera_gc
    cabrera_gc , Aug 12, 2018 :
    Because xiaomi include NATIVE call recorder in all operative sistem
  20. danvxz
    Honeycomb Aug 12, 2018
    danvxz , Aug 12, 2018 :
    It's enabled/disabled depending on what country you're in, because laws. With root you can enable call recording natively no matter what country you're in.
