359
OxygenOS 5.1.4 OTA for the OnePlus 5 & 5T
  1. H1513223534431
    Eclair Aug 19, 2018
    H1513223534431 , Aug 19, 2018 :
    after this 5.1.4 update my OnePlus 5t camera is not properly working in the sense it's shutting down frequently and showing error while opening camera please give some suggestions on this or help me in finding the solution for this issue ...
    Vladut123 likes this.
  2. jithinraj905
    Cupcake Aug 19, 2018
  3. G_Viru
    Jelly Bean Aug 19, 2018
    G_Viru , Aug 19, 2018 :
    clear cache in recovery mode
  4. prudhvieswar
    Donut Aug 19, 2018
  5. danvxz
    Honeycomb Aug 19, 2018
    danvxz , Aug 19, 2018 :
    you tell me
  6. E1533399462584
    Eclair Aug 19, 2018
  7. jayanthramkv
    Eclair Aug 19, 2018
    5star02707, Vladut123 and dashpr like this.
  8. Dexxagon
    Dexxagon , Aug 19, 2018 :
  9. Keith Mayer
    Eclair Aug 19, 2018
    Keith Mayer , Aug 19, 2018 :
    keep up on the good updates! on a side note, will there be a trade in program for the US?
  10. Вася Синицин
    Вася Синицин , Aug 19, 2018 :
    Я удалил кэш из восстановления и из хранилища, но батарея разряжается быстрей все равно и есть проблемы с вайфаем (разрывы и потеря соединения). И так же стал греться сильней мой 1+5.
  11. dashpr
    Vladut123 and jayanthramkv like this.
  12. B1512895711398
    B1512895711398 , Aug 19, 2018 :
    My phone's hotspot setting don't show any password, please let me know my phone's factory set password.
  13. MJ_Vikram
    KitKat Aug 20, 2018
    MJ_Vikram , Aug 20, 2018 :
    Hi it differs from one handset to other, there is option to show Password just click on the check box next to it and it will show you the password.
  14. Chiran_OP5
    Honeycomb Aug 20, 2018
    Chiran_OP5 , Aug 20, 2018 :
    It's ok. Check how much you're getting upto 10%.
  15. Akhil_PA
    Eclair Aug 20, 2018
    Akhil_PA , Aug 20, 2018 :
    After this update camera clarity is worse. Oil painting effect is now enormous. Cant even take a single picture.
    jayanthramkv likes this.
  16. B1510901098139
    Cupcake Aug 20, 2018
    B1510901098139 , Aug 20, 2018 :
    Hey please update Potrate for front cam in one plus 5,Also there is issue of Auto call recording will disabled some times, After reboot it will back. Kindly look into it to resolve & Update at the earliest
  17. qubbus
  18. jayanthramkv
    Eclair Aug 20, 2018
  19. jayanthramkv
    Eclair Aug 20, 2018
    jayanthramkv , Aug 20, 2018 :
    probably, we will recieve patch in next update!
  20. jayanthramkv
    Eclair Aug 20, 2018
