359
OxygenOS 5.1.4 OTA for the OnePlus 5 & 5T
  1. marcusskyfall
    Jelly Bean Jul 29, 2018
    marcusskyfall , Jul 29, 2018 :
    No body on here can supply you with this answer due to OP implementing an incremental roll out. It's a waiting game and it's probably the best way to avoid problems with this build.
    MikeG247 likes this.
  2. F_Chandrasekhar_Vemula_P
    Eclair Jul 29, 2018
    X1517396854503 likes this.
  3. san94fbr
    Gingerbread Jul 29, 2018
  4. Jayeshbhor
    Froyo Jul 29, 2018
  5. iahmedabouzeid
    Cupcake Jul 29, 2018
    iahmedabouzeid , Jul 29, 2018 :
    excuse me , I'm using now 2 apps of VPN but there is no update, I'm in the middle East (Qatar) and I use VPN Canada then Germany then USA and try many times but no update, while I used the same apps before to update and it was working fine
  6. iahmedabouzeid
    I'm using One plus 5
  7. O1518818717608
    Honeycomb Jul 29, 2018
    O1518818717608 , Jul 29, 2018 :
    Only limited number of users got it.
    As it is a stagged roll out.
    I suggest you to go to the original thread rather than creating redundant threads here!
    Aditya vinayak Shinde likes this.
  8. O1518818717608
    You want it not all of them wants it.
    Speak for yourself..
  9. LordSaveUsFromVibration
  10. yukeshyk
    Eclair Jul 29, 2018
    yukeshyk , Jul 29, 2018 :
    update is not based on region,op tm randomly chose devices
    read the thread properly
  11. H1532893874373
  12. bon_truong
    Froyo Jul 29, 2018
  13. G_AkHiL_SingH_eJHu
    Donut Jul 29, 2018
  14. Mike124
    Froyo Jul 29, 2018
  15. X1517396854503
    X1517396854503 , Jul 29, 2018 :
    If I update via OU then will it wipe the data or will it install like an ota update?
    Yogesh Nalvaya likes this.
  16. DogeAlpha
    DogeAlpha , Jul 29, 2018 :
    No wipe
  17. 5star02707
    Ice Cream Sandwich Jul 29, 2018
    5star02707 , Jul 29, 2018 :
    Just a regular update and no wipe
  18. X1517396854503
    Thanks. Last queries, should I select incremental or full update from the options?
    Why is there no other app like OU for OOS and for other phones say Samsung?
  19. angeloalban02
    Froyo Jul 29, 2018
    angeloalban02 , Jul 29, 2018 :
    is this for the open beta version or just for the normal version, because I am not getting the update
  20. P1512569276852
    P1512569276852 , Jul 29, 2018 :
    Yeah, is long process. I don't wanna complicate myself. VPN is sample, but it doesn't works there for this update.
