359
OxygenOS 5.1.4 OTA for the OnePlus 5 & 5T
  1. BuzzAldrin
    Donut Jul 30, 2018
    BuzzAldrin , Jul 30, 2018 :
    My update just arrived now. Using Oxygen Updater from Play Store. Can't tell if image quality is improved yet, need to test further, if it is improved then it is only a small improvement. Anyone noticed a big improvement in Camera?
  2. U1519122434315
    Cupcake Jul 30, 2018
  3. Vineshji27
  4. Sai Nitish
    Honeycomb Jul 30, 2018
    Sai Nitish , Jul 30, 2018 :
    It's a STAGED update and not a REGION based one. So VPN might not work.
  5. sachkharb
    Ice Cream Sandwich Jul 30, 2018
    sachkharb , Jul 30, 2018 :
    no..you will not get this stable ota until you switch to stable version
  6. Ssathiyanarayanan
    Gingerbread Jul 30, 2018
    Ssathiyanarayanan , Jul 30, 2018 :
    Check the system updates page. If you're doesn't appear, then use a VPN & give it try. For some it has worked despite OnePlus' statement that VPN won't do the trick.
  7. danishdaycare
    danishdaycare , Jul 30, 2018 :
    Yes please, do repeat your request. No one here can "send" you any update. Suggest you Google how updates for mobiles work.
  8. sachkharb
    don't know... only Carl can say ;)
  9. alimonu2011
    Eclair Jul 30, 2018
  10. danishdaycare
    Try restarting your router.
  11. sachkharb
    This OTA will have a staged rollout, the OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs, so using VPN to download this build might not work as the rollout is not based on regions and is randomly pushed out to a limited number of devices.
    see post 1
  12. danishdaycare
    Read first post.
  13. sachkharb
    try oxygen updater... it's the best way because vpn z nt working in this ota
  14. danishdaycare
    Yes. Read first post. All info there. Always start reading first post.
  15. sachkharb
    try oxygen updater ..
  16. danishdaycare
    C
    Clear cache in recovery.
  17. sachkharb
    not at all... clear cache in recovery... this will work.. and if not then perform a factory reset.
  18. sachkharb
    try oxygen updater
  19. sachkharb
  20. sachkharb
    I think oxygen updater is much better option to do that
