316
OxygenOS 5.1.5 OTA for the OnePlus 5 & 5T
  1. Mr_Cyrox KitKat Oct 11, 2018
    Mr_Cyrox, Oct 11, 2018 :
    Just to get this out of the way there are no OnePlus employee here...
    Also there is a bug in OxygenOS 5.1.5 where you can't make phone calls with Bluetooth devices...
    There is a temporary solution but you have to search to find it...
    There are plenty of threads about this...
    Also this is going to be fixed in the next update...
    Ravi BINAVAT and Akshay25 like this.
  2. Akshay25 Donut Oct 11, 2018
    Ravi BINAVAT likes this.
  3. dhj49er Gingerbread Oct 11, 2018
    dhj49er, Oct 11, 2018 :
    Does 5.1.5 have the status bar notch - the wide notch of the 6?
    Is there an option to disable the status bar notch?
    If not, I believe there should be.
    I understand the 6T may have a much smaller V style notch. Do you think OP will change the 5T status bar notch to the smaller V?
  4. Mr_Cyrox KitKat Oct 11, 2018
    You talking about the empty space in Quick Settings?
    That is "by design" and might not change
  5. dhj49er Gingerbread Oct 11, 2018
    Yes, the unused unavailable wasted space
    In my opinion a strange design decision.
    The 5T doesn't have a notch display, so no need for the software to implement a notch.
    Maybe the design should change to reflect the V shaped notch of the 6T.
    Why not?
  6. Mr_Cyrox KitKat Oct 11, 2018
    That QS (Quick Settings) was added when Oreo 8.1 was released for 5/5T...
    Before OnePlus 6...
    And it's not changing...
  7. dhj49er Gingerbread Oct 11, 2018
    So it's just the Quick settings?
    The status bar doesn't have a notch?
  8. Mr_Cyrox KitKat Oct 11, 2018
    I don't understand but maybe these screenshots will help...
    About what are you talking about?
    Refer to one of my screenshots (I'm running beta just to let you know)
  9. Y1539260991516 Cupcake Oct 11, 2018
  10. Mr_Cyrox KitKat Oct 11, 2018
    You have to delete your pin and add it again
    Search next time
  11. dhj49er Gingerbread Oct 11, 2018
    The status bar - top line of the display - go to home screen and see the icons for Bluetooth, WiFi, phone etc. On 8.0 the full line is available.
    I understood that 8.1implemented a status bar with a central area (the so called notch) where nothing can be displayed. Is that the case?
    The workaround, I believe, is to have a blank top line and put the status bar on a full line below it.
  12. Mr_Cyrox KitKat Oct 11, 2018
    You mean this?
    That was not in Oreo 8.1 update from Google...
    For same unknown reason OnePlus decided to "expand" QS panel...
    The notch support was added in Android 9...
    There is a work around...
    Substratum (if you don't have root you need to buy an addon andromena)
  13. themightypathan Gingerbread Oct 11, 2018
  14. Mri2907 Froyo Oct 11, 2018
  15. Aziz_Amin_Oneplus Ice Cream Sandwich Oct 11, 2018
    Aziz_Amin_Oneplus, Oct 11, 2018 :
    Just wait for 10 days more and then you guys will get the update you all were waiting for ok, now no more shouts on the next update till then.
  16. Funk Wizard Lollipop Moderator Oct 11, 2018
    Funk Wizard, Oct 11, 2018 :
    Thread merged with the release thread, continue discussion there
  17. Batta1982 Donut Oct 11, 2018
  18. Mr_Cyrox KitKat Oct 11, 2018
    When it's stable
    Ravi BINAVAT and Batta1982 like this.
  19. crackmindarjun Cupcake Oct 11, 2018
  20. Mr_Cyrox KitKat Oct 11, 2018
    Wait till winter then...
    No need to say the obvious ;)
    Ravi BINAVAT and crackmindarjun like this.
