318
OxygenOS 5.1.5 OTA for the OnePlus 5 & 5T
  1. Arsath1994
    Froyo Aug 27, 2018
    Arsath1994 , Aug 27, 2018 :
    After the update,
    In my full screen apps, status bar notification swiping is not working.
  2. Raviraj.bv
    Cupcake Aug 27, 2018
    Raviraj.bv , Aug 27, 2018 :
    hi after updating oxygen OS my JBL Bluetooth hands free is not working?? so please resolve my problem..
  3. stark2991_PL
    KitKat Aug 27, 2018
    stark2991_PL , Aug 27, 2018 :
    2GB of RAM is probably reserved for camera and other system stuff. I can't go below 1,8GB of free memory
    Clear cache after the update
    Disable PIN and enable again
    People... Everything was told hunderd of times already
    windliao and bharathj85 like this.
  4. danishdaycare
    Ice Cream Sandwich Aug 27, 2018
    danishdaycare , Aug 27, 2018 :
    Sit down.
  5. danishdaycare
    Post battery stats otherwise noone can help you.
  6. danishdaycare
    bharathj85 likes this.
  7. F1532426719188
    Eclair Aug 27, 2018
    F1532426719188 , Aug 27, 2018 :
    One Plus what happen to the camera pic clarity.. its been degraded to it worst level. i took the update day before yesterday and after that.. portrait mode is having huge level of oil painting.. front facing camera has issues as well. didnt face this type of issues since Jan when i bought 5T.
    specially auto HDR mode is too much degraded. can you please look into this issue and put to through testing... very dissapointed by this.
    hope for quick solution.
  8. sathishselvaraj
    sathishselvaraj , Aug 27, 2018 :
    I got the Update yesterday
  9. Ashwin5013
  10. Zaphodrocks
    Zaphodrocks , Aug 27, 2018 :
    Not draining for me, so you check it.
    stark2991_PL likes this.
  11. Icecreamypie
    iJohnnyCash likes this.
  12. S1520320058549
    devanshsadhotra likes this.
  13. G_sadaqat_rubani_Tams
    Froyo Aug 27, 2018
  14. iJohnnyCash
    iJohnnyCash , Aug 27, 2018 :
    I found it.
    To enable this feature just try to reset (change) the pin. Then someone can see the relevant option!
  15. sidsonite
    Froyo Aug 27, 2018
    sidsonite , Aug 27, 2018 :
    hey! OnePlus! please do add one handed mode in your upcoming update, it's helpful for using the large screen
  16. vishalkumar94487
  17. alhazparmar
  18. Trevor.Hawkes
    Trevor.Hawkes , Aug 27, 2018 :
    Update to 515 then you have it.
  19. alhazparmar
    alhazparmar , Aug 27, 2018 :
    5.1.5 to update op5_o2_beta_16 . next?
  20. alhazparmar
