318
OxygenOS 5.1.5 OTA for the OnePlus 5 & 5T
  1. Anshit Mandloi
    Eclair Aug 28, 2018
    Anshit Mandloi , Aug 28, 2018 :
    Confirm pin without tick does not work in App lock....will be nice toh have the feature implemented there also
  2. Boersenfeger
    Froyo Aug 28, 2018
    Boersenfeger , Aug 28, 2018 :
    After all, only a remote session, which I successfully ran online this morning with a OnePlus support employee, helped against the stack in fast boot mode... Now my 5T runs again with version 5.1.4 and the update to 5.1.5 is already displayed. But I install this only after my short vacation...
    To everyone who helped me with my problem or at least tried to help me, I say thank you very much.
    This is a great community!
    But I have one more request...
    It would be nice if users with problems would first look into the respective thread and work through the already given tips.
    Thanks again and see you soon... :)
    Translated with www.DeepL.com/Translator
  3. stevenchow90
    Gingerbread Aug 28, 2018
  4. G_T_Bennett
    Jelly Bean Aug 28, 2018
    G_T_Bennett , Aug 28, 2018 :
    This can be found very easily on Google or YouTube.
  5. hnmprasad
    Cupcake Aug 28, 2018
    hnmprasad , Aug 28, 2018 :
    After update also pin lock not opening without tapping ✔ symbol. no change after update
  6. vincent.manjuran
    vincent.manjuran , Aug 28, 2018 :
    OnePlus needs to do their part.
  7. Aziz_Amin_Oneplus
    Aziz_Amin_Oneplus , Aug 28, 2018 :
    Rubbish it's not been a year since 5t came out and you are saying my 5t was dead in 1.2 years, what a joke??
  8. MJ_Vikram
    KitKat Aug 28, 2018
    MJ_Vikram , Aug 28, 2018 :
    check the Confirm PIN without tapping √ to unlock the phone (Settings -> Security & lock screen -> Screen lock -> PIN)
  9. tvkuttalam
    Donut Aug 28, 2018
    tvkuttalam , Aug 28, 2018 :
    I am also facing the same problem here. As a workaround you need to restart your phone everytime you want to connect to your Bluetooth device
  10. R1508272766729
  11. rsharma3512
    Eclair Aug 28, 2018
  12. D1509170163570
    Donut Aug 28, 2018
    D1509170163570 , Aug 28, 2018 :
    this update broke audio over Bluetooth. i have a pair of earphones that use the aptX codec. the audio stream seems very flat since the update. the bass is very subdued and the audio generally lacks clarity.
    the earphones work fine on any other device, just as it did with my OP5 before the update.
  13. winslo666
    winslo666 , Aug 28, 2018 :
    Bey guys anybody experiences any problems in bluetooth connectivity after the update to 5.1.5?
    Kdathe likes this.
  14. Mithun Kumar Gumgaonkar
    Mithun Kumar Gumgaonkar , Aug 28, 2018 :
    There has been considerable slow down in performance of my oneplus 5 after updating to 5.1.5. Three days ago I updated my phone. Initially I thought it was just me. But after few days of use I realised that there has been quite visible slow down in performance. Animations looks like they are not holding their frames per second. After almost 14 months of purchase of OP 5, first time I have seen my phone legging.
    Sorry oneplus...but I think you should look into it and try to make as fast as it was before update.
    Anyone having the same issue....!!??
    Mrinal kirtaniya likes this.
  15. Cervantes
    Lollipop Moderator Aug 28, 2018
    Cervantes , Aug 28, 2018 :
    This is a thread of update questions
    Thread merged
  16. stark2991_PL
    KitKat Aug 28, 2018
    stark2991_PL , Aug 28, 2018 :
    Wipe cache. If it won't help, then backup your data and do a factory reset. Your phone will be super fast again, 100% sure.
    Kdathe likes this.
  17. nikhilgarg.98
    Donut Aug 28, 2018
    nikhilgarg.98 , Aug 28, 2018 :
    okay i will try doing that [e]1f60a[/e]
    sachkharb likes this.
  18. mdegeus
    Eclair Aug 28, 2018
    mdegeus , Aug 28, 2018 :
    yes. A couple of updates ago i had the same problems with disconnecting Bluetooth. That problem was solved. But nearly the same problem is back after the 5.1.5 update. My phone is working in my car but the car dosn't play the music from my phone anymore. i re-installed update 5.1.4. hopefully this will work. And yes...i cleared chache in recovery (about 5 times)
  19. Johitaa_Ghosh
    Johitaa_Ghosh , Aug 28, 2018 :
    The battery drain is tremendous. Android and screen are eating into the battery and also annoying pop up advertisements have come in. Can you please help?
  20. Hanok.m
    Hanok.m , Aug 28, 2018 :
    after the update battery draining fast need to charge twice per day .before the update having one full charge covered 24 hours within heavy data usage ....
