409
OxygenOS 5.1.6(5.1.7 Hotfix) OTA for the OnePlus 5 & 5T
  1. prithviraj_mn
    Froyo Nov 17, 2018
    prithviraj_mn , Nov 17, 2018 :
    after updating to this versions (5.1.7 hotfix)
    my Instagram parellel app started crashing always. not able to open it . kindly do help..
    EdgarCorreia likes this.
  2. EdgarCorreia
    Cupcake Nov 17, 2018
    EdgarCorreia , Nov 17, 2018 :
    Olá, depois de ter feito a actualização o meu Instagram deixou de trabalhar. aconteceu o mesmo a mais algum.
    Hello, after having made the update my Instagram stopped working. the same happened to some others.
    Note: I already solved the problem, I had to uninstall and re-install the application.
  3. DanGreenstein
    Froyo Nov 17, 2018
    DanGreenstein , Nov 17, 2018 :
    since this update both Google maps and Hangouts do not connect properly over cellular data. I tried clearing caches from the app and recovery mode. is is this an issue with the update or is there a way to fix it?
  4. G_Ayan_Paul_FCha
  5. ruder1
    ruder1 , Nov 17, 2018 :
    Yesterday I made three OTA upgrades from 5.1.1 on my 1 + 5t: 5.1.4, 5.1.5, 5.1.7.
    After each - clearing cash. Everything works fine, * # * # 4636 # * # * works, there is no problem with the bluetooth, I still check the battery, but it seems to keep it as before.
  6. noomiij
  7. amirul_lisan
    Ice Cream Sandwich Nov 17, 2018
  8. Cervantes
    Moderator Moderator Nov 17, 2018
    Cervantes , Nov 17, 2018 :
    Review the forum
    Phone hangs
    reboot the phone, close applications, clean the temporary memory: wipe cache
    Battery problems, review the first post of:
    https://forums.oneplus.com/threads/...our-stats-how-to-improve-battery-life.681970/
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
  9. harshitdhoot
    Eclair Nov 17, 2018
    harshitdhoot , Nov 17, 2018 :
    One of the bad software update...
    Unable to hear sound without earphone on google play music app...
    Pls fix this bug @OnePlus_IN
    This is really bad...!
    If i am using earphone then i am hearing sound but without earphone on phone only i am unable to hear sound...!
    Fix this bug as soon as possible....
    This problem came after updating to 5.1.7...
  10. G_Parthesh_Jadhav_TNSs
    Gingerbread Nov 17, 2018
    G_Parthesh_Jadhav_TNSs , Nov 17, 2018 :
    hi guys, a day ago I format my all storage and os too from twrp and at that time I was having 4.5.7(7.1.1) file in my pc so i flashed that but now I can't update to (8.1)5.1.16/17.... any suggestions plz[e]1f62d[/e][e]1f62d[/e] somebody help[e]1f62d[/e][e]1f62d[/e]
  11. SurajSinghal2107
    Donut Nov 17, 2018
    SurajSinghal2107 , Nov 17, 2018 :
    ---Update on the above issue after wiping the cache---
    Hello OnePlus community,
    Good Afternoon.
    As one of the community member suggested me to wipe the cache, I did the same. Fortunately it worked for me!!! My OnePlus 5's battery endurance has been restored. It is giving me around 6 hours of Screen On time which is great considering it is a year old device.
    Thank you very much for helping me out.
    Best regards,
    Suraj Singhal.
    5star02707 likes this.
  12. chigo58
    Eclair Nov 17, 2018
    chigo58 , Nov 17, 2018 :
    No no more problems but I had to clear cache from recovery after flash .all good.
  13. N1520237764202
  14. B_Wrath
    Nougat Nov 17, 2018
    B_Wrath , Nov 17, 2018 :
    What was wrong in reading the update announcement thread and knowing it for yourself?
    Don't create redundant threads!
  15. N1520237764202
    N1520237764202 , Nov 17, 2018 :
    I have read the previous updates.. since they encountered problems.. I was hoping those were fixed by now.. so I was wondering if it is safe to update already?!
  16. B_Wrath
    Nougat Nov 17, 2018
    And like i told you, read the latest update announcement thread and make a decision for yourself.
    Budruel likes this.
  17. danishdaycare
    danishdaycare , Nov 17, 2018 :
    No. After the update my neighbors got divorced. Why OnePlus, why?
  18. danishdaycare
    Instead of ranting give us more details what you've done to solve the problem! Did you restart your phone? Clear the apps cache? Clear data of the app? Finally clear cache in recovery?
    Sid_Ck likes this.
  19. G_Vivek_Gulia_kHGC
    G_Vivek_Gulia_kHGC , Nov 17, 2018 :
    i have done all the things that you mentioned. but the problem is still there. even the touch screen stops working many a time in every update.
  20. danishdaycare
    Charge your phone to 100% and use it as you do till you reach 10-15%. Take screenshot of you battery graph and the apps that used up your battery and we'll go from there. And, check your apps, any draining your battery? And also untic wifi and Bluetooth always on under location menu.
