393
OxygenOS 5.1.6 OTA for the OnePlus 6
  1. Jack4001
    Froyo Jun 12, 2018
  2. noquarter
    Lollipop Jun 12, 2018
    noquarter , Jun 12, 2018 :
    No if you choose "wipe cache" at step 5
    Hydra Bob, Sun90 and Jack4001 like this.
  3. Jack4001
    Froyo Jun 12, 2018
    Jack4001 , Jun 12, 2018 :
    will do that, thanks again
    noquarter likes this.
  4. vishalvkd
    Cupcake Jun 12, 2018
    vishalvkd , Jun 12, 2018 :
    why true caller app is not working in background even the permission to use in background is ON
    I'm not getting unknown caller ID when anybody IS calling
    same prob with my friends mobile also
    look into matter ASAP
  5. C1528793121164
    C1528793121164 , Jun 12, 2018 :
    Even I got they update yesterday. sound quality really improved. sound was the major draw back of one plus 6. but they improve the sound as well. thumbsup to one plus. thank you.
  6. brnogu
    Eclair Jun 12, 2018
    brnogu , Jun 12, 2018 :
    I've tried this but the minimum notifications sound is still to high.
  7. C1528793121164
    don't know man, is their any prblm wit sound
  8. subramaniant2001
    Donut Jun 12, 2018
    subramaniant2001 , Jun 12, 2018 :
    My update after using 5.1.6 for a day.
    1. Phone freezes when used in 4G mode. I have switched to 2G/3G mode and works fine.
    2. Battery health remains the same, I don't see any changes before and after the update.
    3. Camera is working fine. Bokeh effect is seen in front camera. Yet to try the rear cam.
    4. Notifications are working fine.
    5. Fingerprint has become considerably slow. Both face unlock and finger print operates at the same speed.
    6. Overall phone has become little slow though not visible much.
    7. Few Notification tones are very loud. Unable to reduce the tone volume below a certain point which is annoying and forced to put in vibrate mode.
    Tusharkhilari likes this.
  9. Michelle Martinez Caamaño
    Froyo Jun 12, 2018
  10. fidus62
    Jelly Bean Jun 12, 2018
    fidus62 , Jun 12, 2018 :
    no
  11. tony1976
  12. Jack4001
    Froyo Jun 12, 2018
    it was solution for battery draining problem after update.
  13. fidus62
    :D
  14. Chandan Kumar Bandaru
    Chandan Kumar Bandaru , Jun 12, 2018 :
    My OnePlus 6 hangs frequently after recent update
    it's haging frequently, screen goes off, blue notification light turns on.
    it's happening while opening apps, some times while at rest.
  15. Jithin Sathees Panicker
    Jithin Sathees Panicker , Jun 12, 2018 :
    The network speed is shown only when i swipe down the notification panel. Kindly take this seriously and provide an update to fix this issue.
  16. Tusharkhilari
  17. devdipta
    Froyo Jun 12, 2018
  18. Catalin_Buzescu
    Catalin_Buzescu , Jun 12, 2018 :
    As you can see, Android system is not letting your phone go to sleep. Did you read the instructions and cleared cache from settings and recovery after the update?
  19. Q1528795334753
  20. brnogu
    Eclair Jun 12, 2018
    Hehehe
    Ok, so the only solitiso is to wait for a new update right?
