393
OxygenOS 5.1.6 OTA for the OnePlus 6
  1. S1527836005146
    Cupcake Jun 13, 2018
    S1527836005146 , Jun 13, 2018 :
    since 5.1.6 update, my oneplus 6 has crashed two times. it doenst lags but gets stuck instead. Is anyone else facing the same issue?
  2. Yannis Neris
    Ice Cream Sandwich Jun 13, 2018
    Yannis Neris , Jun 13, 2018 :
    Can you apply a screenshot from your battery graph?
    Nothing will be changed by just opening multiple threads that your battery drains to fast
  3. G1528870809855
    Donut Jun 13, 2018
    G1528870809855 , Jun 13, 2018 :
    yes will send it
  4. wiktoria_popiolek
    wiktoria_popiolek , Jun 13, 2018 :
    Hi,
    Has someone else had problem with battery life after the update? I used VPN to get an update and the next day this happened...
    I did not install new apps or anything. Phone is super hot to touch while using and battery lasts abour hour or two. Also my OP6 didn't last though the night having 50% battery. Anyone? Please help.
    G1528870809855 likes this.
  5. G1528870809855
    Donut Jun 13, 2018
    facing the same issue please anyone help
  6. wiktoria_popiolek
    I get them too. Usually restarting the app works
  7. bejadan
    bejadan , Jun 13, 2018 :
    For the battery problem wipping the cache solved it...thanks !! This should be done automatically in the update process ... Most people won't know that they have to do it I think...
    Anyway thanks again
  8. chirag.chandaliya
  9. Yannis Neris
    67% android system battery drain!!!!....
    Definitely something wrong with your setup!!...
    Factory reset is the only option
    fidus62 likes this.
  10. sdesai264
    Eclair Jun 13, 2018
    sdesai264 , Jun 13, 2018 :
    Severe network issues On One plus 6 post this update...calls not reachable even when the network is full in India ...
  11. G1528870809855
    Donut Jun 13, 2018
    how shd I do it please explain the procedure
  12. wiktoria_popiolek
  13. Imanol Anta Larrea
    Imanol Anta Larrea , Jun 13, 2018 :
    Una pregunta por si alguno me la puede responder: la actualización vendrá sola al móvil y solo hay que instalarla o hay qué descargarla de internet en instalarla por tu cuenta?
    Gracias!
    I have a question: this new update IS going to be given by Oneplus directly to the movilephone or I must download this update from the inthernet?
    Thank you!
  14. Beeu
    Beeu , Jun 13, 2018 :
    Hi I've tried VPN change to Germany or Canada method but still didn't get the oxygenos5.1.6 update . And how do I place the file into root directory?And I'm from Malaysia.
  15. Cheetosdust
    Starting Point Expert Jun 13, 2018
    Cheetosdust , Jun 13, 2018 :
    You don't need to download it. It will appear on your phone over the air (OTA).
    Since this was an incremental upgrade, some users get it before others, but in the end, everyone will get 5.1.6.
  16. S1528879537551
  17. S1528879537551
    S1528879537551 , Jun 13, 2018 :
    yes I too have same issue
  18. Naveen_RajR
  19. Naveen_RajR
  20. Terryruiz
