393
OxygenOS 5.1.6 OTA for the OnePlus 6
  1. Y1527915771481
    Cupcake Jun 13, 2018
    Y1527915771481 , Jun 13, 2018 :
    After update, phone is getting blank and not responding or powering up. I had to switch off and on the phone. It's happening continually
  2. J1527936974876
    Donut Jun 13, 2018
    J1527936974876 , Jun 13, 2018 :
    I received the pop up, when as soon as I connected to WiFi, it disappeared. how can I get the link?
  3. Sun90
    Starting Point Expert Jun 13, 2018
    Sun90 , Jun 13, 2018 :
    No
  4. Aviskumar
    G1528870809855 and hiteshredekar like this.
  5. Imanol Anta Larrea
    Imanol Anta Larrea , Jun 13, 2018 :
    Okey thank you, so i must wait until Oneplus gives me the new update! and do you know when can they give this update?
  6. Naveen_RajR
    Naveen_RajR , Jun 13, 2018 :
    yes same problem i faced.
  7. dermot33
    Ice Cream Sandwich Jun 13, 2018
    dermot33 , Jun 13, 2018 :
    I n advanced - gaming mode,Is it normal to have the block notification toggle enabled by default ?
    Does gaming mode only work if you add apps for the mode ?
    Trying to figure out why I'm not hearing some notifications
  8. Cheetosdust
    Cheetosdust , Jun 13, 2018 :
    It was not confirmed. I can tell you I got mine - not using a VPN or the Oxygen Updater - last Monday.
    Check Settings - System Update from time to time ;)
  9. G_sai_goutham_HMNR
    Froyo Jun 13, 2018
    G_sai_goutham_HMNR , Jun 13, 2018 :
    try wipe cache, even after then it doesn't work then go with factory reset. I tried wipe cache. follow these steps. switch off ua MBL.. press power button and volume down button at same time until your phone asks for password (if you set) then choose the language. then after select the wipe cache and data. then select the wipe cache only. it helped me. try from ua end.
  10. karthika_j
    karthika_j , Jun 13, 2018 :
    after this update my phone is hanging. Mobile data turns off automatically . does anyone experience any issues like this ?
  11. Y1528388691127
    Donut Jun 13, 2018
    Y1528388691127 , Jun 13, 2018 :
    Front camera portrait mode is worst ... not able to focus multiple people ..edge detection is really bad. Everyone experiencing same issue or not
    T1528874348809 likes this.
  12. sagarkls
    Froyo Jun 13, 2018
    sagarkls , Jun 13, 2018 :
    guyz did anyone notice that while recording video in 720 p, 1080 nd 4k in full zoom 8x the camera is not stable as it shakes a bit.but in the 1080 60fps nd 4k 60fps it records nice video inthe full zoom 8x.why this is happennig
  13. G1528870809855
    Donut Jun 13, 2018
  14. G_Lenon_Dsouz_A_
    G_Lenon_Dsouz_A_ , Jun 13, 2018 :
    I once paused the update while downloading and closed the app. now I cannot update, phone's showing my system is up to date. please help
  15. ananthu
    Froyo Jun 13, 2018
    ananthu , Jun 13, 2018 :
    As reported by Erica Griffin, the OnePlus 6 only uses EIS when shooting in 30 FPS modes whereas it uses the OIS when shooting in any of the 60 FPS modes. The reasons are anyone's guess at the moment. But when you zoom in, the system has to compromise between stability and resolution. This is because EIS itself works by cropping the image from the sensor and then using information from the gyroscope to use the data from the regions outside the FOV to achieve the stabilized effect (this is an extremely crude explanation of EIS). Zooming further crops into the image and I think at 8X, the available resolution from the sensor is not enough for the EIS to compensate to the required degree. As noted by Erica, you can put the camera in any of the 60 FPS modes and observe the primary lens while wobbling the camera to see the OIS in action. The same won't be visible when using the 30 FPS modes.
    Sun90, Joel B and otto2 like this.
  16. i030809
    Froyo Jun 13, 2018
    i030809 , Jun 13, 2018 :
    Congratulations... This update is what I need... Battery life increase, The sound quality is improved, On benchmarks it takes the 1st place, much faster ;-) Thank you OnePlus...
    G1528870809855 likes this.
  17. G1528870809855
    Donut Jun 13, 2018
    G1528870809855 , Jun 13, 2018 :
    not at all it decreases it's battery life draining like crazy
    i030809 likes this.
  18. G_sai_goutham_HMNR
    Froyo Jun 13, 2018
    for few the battery life has increased.
    i030809 likes this.
  19. G_Lenon_Dsouz_A_
  20. izzykasha
    Lollipop Jun 13, 2018
    izzykasha , Jun 13, 2018 :
    the update has been pulled so it's not available at the moment.
    bug fixing by oneplus
    G_sai_goutham_HMNR likes this.
