388
OxygenOS 5.1.6 OTA for the OnePlus 6
  1. K1528905585914 Cupcake Jun 13, 2018
  2. G_sai_goutham_HMNR Eclair Jun 13, 2018
    G_sai_goutham_HMNR, Jun 13, 2018 :
    it's there and has focus issue for more than one
  3. K1528905585914 Cupcake Jun 13, 2018
  4. getcsv Cupcake Jun 13, 2018
    getcsv, Jun 13, 2018 :
    where to select Canada VPN please?
  5. V1528906791331 Cupcake Jun 13, 2018
    V1528906791331, Jun 13, 2018 :
    I recently installed the latest Oxygen OS update on my OP6 (India), and since then the battery seems to be running out much quicker than it used to before the update.
    This despite if the Battery Optimization option being kept on.
    The battery consumption is about 25-30% faster than before.
    Please look into this matter.
    ppavan1 likes this.
  6. G_sai_goutham_HMNR Eclair Jun 13, 2018
    V1528906791331
    Please look into this matter.​
    hey.. this is with most of the people and the latest update has been rolled back it seems. my suggestion is to wipe the cache data and check. I did that and could see better battery performance than before.
    V1528906791331 likes this.
  7. Ansh sachdeva Cupcake Jun 13, 2018
    ppavan1 likes this.
  8. Sun90 Starting Point Expert Jun 13, 2018
    Sun90, Jun 13, 2018 :
    They will.
    Wait for now.
    otto2 likes this.
  9. KALYAN490 Eclair Jun 13, 2018
    KALYAN490, Jun 13, 2018 :
    once installed turbo VPN u will get right side top corner by default India so please select Canada instead of India then connect .
  10. V1528906791331 Cupcake Jun 13, 2018
    Thanks mate, done that and will keep a close eye on the performance change if any.
  11. G_sai_goutham_HMNR Eclair Jun 13, 2018
    hey.. how you wiped the cache data? follow the steps if you're not aware. switch off the mobile, press power button and volume down button at the same time for 10secs. then the system will ask for your password if you set then have to select the language then select wipe cache and data. then select wipe cache not the data if you select wipe data then I vl loose your data. after clicking the wipe cache then u have to restart the device.
  12. V1528906791331 Cupcake Jun 13, 2018
    l simply cleared it from the settings option. Will try the method you've recommended too. Thanks a bunch again! :)
  13. G_sai_goutham_HMNR Eclair Jun 13, 2018
    np. help others too..
    johneebee likes this.
  14. E1528826293795 Cupcake Jun 13, 2018
  15. G_sai_goutham_HMNR Eclair Jun 13, 2018
    no need to do anything as the company has rolled back the current one which has bugs. wait for the latest one. keep an eye on the thread or community
  16. V1528906791331 Cupcake Jun 13, 2018
    KoVeN likes this.
  17. E1528826293795 Cupcake Jun 13, 2018
    E1528826293795, Jun 13, 2018 :
    thank you
  18. Vilasmudireddy Cupcake Jun 13, 2018
  19. G_sai_goutham_HMNR Eclair Jun 13, 2018
  20. S1528912638173 Cupcake Jun 13, 2018
