393
OxygenOS 5.1.6 OTA for the OnePlus 6
  1. Terryruiz
    Ice Cream Sandwich Jun 14, 2018
    Terryruiz , Jun 14, 2018 :
    does your OnePlus 6 fingerprint sensor bring it down ?? like the OnePlus 5T does ??
  2. Satyajeet10601
    Donut Jun 14, 2018
    Satyajeet10601 , Jun 14, 2018 :
    nopes... but my friend uses onplus5t software in his oneplus6.. and it does bring its notification bar down...
  3. Terryruiz
    ask your friend how he did it then
  4. Satyajeet10601
    Donut Jun 14, 2018
    listen terry... i think its a cool feature to pull down the notification bar through fingerprint gesture... and i wanted to ask the Oneplus authority that if possible to include it in next update... none of these was intended for YOUR concern
  5. NikosTweak
    Cupcake Jun 14, 2018
    NikosTweak , Jun 14, 2018 :
    Is this OnePlus6Oxygen_22_OTA_012_all_1806140300_9847af0617144409.zip the final version? from 5.1
    8?
    mc-milan likes this.
  6. BMG1900
    Froyo Jun 14, 2018
    BMG1900 , Jun 14, 2018 :
    I usally stay quiet, but enough is enough - You ask a question that has been answered in the past 160 pages - Either read through the pages or use search
    Lunatico likes this.
  7. ronniefknpickering
    ronniefknpickering , Jun 14, 2018 :
    Hi my OP6 just arrived today and I have nearly set it all up however I’ve come across a problem. I’ve searched for a solution to this but can’t find it. I have set ‘automatic’ to my face unlock but it requires me to press the power button every time? Is there a way around this.
  8. Kytharsis
    Marshmallow Jun 14, 2018
    Kytharsis , Jun 14, 2018 :
    This just means it'll bypass the lock screen as it sees your face as soon as you turn on the phone. It's not gonna constantly check for your face while the screen is off.
  9. ronniefknpickering
    Sorry I don’t think I can explained my self well enough, I was wondering why my face unlock isn’t automatically unlocking as it it requires me to press the on/off button every time. I have enabled the auto unlock
  10. Jus Wil
    Gingerbread Jun 14, 2018
    Jus Wil , Jun 14, 2018 :
    How does the dual SIM 4g feature work.? I have data on both SIM cards but it only uses one at a time
  11. Kytharsis
    You mean you have to press the power button to turn on the screen for it to detect your face?
  12. ronniefknpickering
    Yes and I was wondering if there was a way around that
  13. Kytharsis
    You can enable double-tap to wake. As I said in the previous post, it's not gonna constantly search for your face while the screen is off. It has to be on.
  14. StefanBalcan
    StefanBalcan , Jun 14, 2018 :
    Can anyone tell me how the VPN stuff working? I downloaded turbo VPN then set it to Canada then...
    And how to move downloaded zip to root?
    Thanks in advance!
  15. Deactivated User
    Jun 14, 2018
  16. D1527635172129
    Cupcake Jun 15, 2018
  17. Ptk707
    Froyo Jun 15, 2018
  18. Stanley08
    Gingerbread Jun 15, 2018
    Stanley08 , Jun 15, 2018 :
    I use Savage VPN
    It was pulled I think. Wait. A new one should come soon.
  19. G_Murukonda_Vinayak_gAbv
    Froyo Jun 15, 2018
    G_Murukonda_Vinayak_gAbv , Jun 15, 2018 :
    hello , this update completely ate up my battery capacity it bare gives 18 hrs back up even i keep dark background low display brightness, less third party apps stopped playing games. After all this from 10.30 to mrng 5.30 it ate 17% of battery. Thats idle time no screen is on, no app was running nothing yet it came down from 33% to 16% . Man somebody help here. can i roll back to my older version i don care about the portrait selfie now all i need is my battery capacity back, earlier it gave me more than 24 hrs if i used it at low brightness and less gaming now no trace of anything near . I was excited to see that this update has battery optimisation,i thought i am voing to get even more hrs of charge life. but it is no good. It just killed my phones battery. please roll me out of it back.
    C1527912340476 likes this.
  20. Lorena1351
    Lorena1351 , Jun 15, 2018 :
    does this update include the ability to change specific contact notification sounds? just switched from a Nexus 6p to OnePlus 6
