393
OxygenOS 5.1.6 OTA for the OnePlus 6
  1. paby.K
    Froyo Jun 10, 2018
    RahuLSanjayPatiL likes this.
  2. SIDDIQUISAUD
    Cupcake Jun 10, 2018
  3. RahuLSanjayPatiL
    Eclair Jun 10, 2018
    RahuLSanjayPatiL , Jun 10, 2018 :
    Never ! Leaving away technical part, long story short, you are just downloading desired content "through" it. Once you have what you want, just uninstall that VPN.
    Enjoy, hope this help :)
  4. RahuLSanjayPatiL
    Eclair Jun 10, 2018
  5. MohdSaifHussain
    MohdSaifHussain , Jun 10, 2018 :
    yes. i did removed the VPN. and thanx a ton. it's a sigh of relief. My friend was quoting the same but I was not sure. wanted to confirm with the community ,[e]2764[/e]️
  6. RahuLSanjayPatiL
    Eclair Jun 10, 2018
    Anytime buddy :)
  7. bittss2
    Froyo Jun 10, 2018
    bittss2 , Jun 10, 2018 :
    I am from India, and In india this update will come within this week to all OnePlus 6 device.. but if u want to receive the update like right now than just download a vpn app from play store and select Canada region. You will get a OTA update notification in just 5 minutes or you can check in your system update from setting menu.
    P.S : I am using Thunder VPN
    And after installing the update remove the VPN or disconnect it.
  8. Lakshmaiah4136
  9. Pankajm28.pm
    Froyo Jun 10, 2018
    Pankajm28.pm , Jun 10, 2018 :
    please try optimising the vibration motor
    vibration is too low even after adjusting it to strong intensity
  10. RahuLSanjayPatiL
    Eclair Jun 10, 2018
    Please see the previous comment, just top of your's ;)
  11. bittss2
    Froyo Jun 10, 2018
    after updating..
  12. paldinesh
    Donut Jun 10, 2018
    paldinesh , Jun 10, 2018 :
    same here .. please fix the issue
  13. Yashvendra_Singh_Raghav
    Ice Cream Sandwich Jun 10, 2018
    Yashvendra_Singh_Raghav , Jun 10, 2018 :
    if you are using one plus 6 and u r in india... the OTA update take 1 week more to reach you.
    if you want quick to download this update.
    1.download vpn app from play store.
    vpn master (vpn app name).
    download this.
    2.select region Germany or canada nd then connect.
    after you got connected ..
    3. then go to system update.
    you will find OTA update Oxygen os 5.1.6 for one plus 6.
    download nd install it.
    its safe... u will not face any issue
    kvnreddy likes this.
  14. Kalyanthanikonda
  15. paldinesh
    Donut Jun 10, 2018
    please fix fingerprint unlock .. sometimes it doesn't recognizes and we have to on by power button.
    ppavan1 and Joby Varghese like this.
  16. Kaushik_mdas
    Donut Jun 10, 2018
  17. jithinbabu838
    Froyo Jun 10, 2018
  18. rajkumar1996
    Froyo Jun 10, 2018
  19. Q1528311406946
    Q1528311406946 , Jun 10, 2018 :
    I want to be update
  20. SubhashNayak
    Honeycomb Jun 10, 2018
    SubhashNayak , Jun 10, 2018 :
    Are you sure your hands are not blocking proximity sensor when you touch finger print reader.
