393
OxygenOS 5.1.6 OTA for the OnePlus 6
  1. TonioLA
    Ice Cream Sandwich Jun 9, 2018
  2. T1514687486610
    Eclair Jun 9, 2018
    T1514687486610 , Jun 9, 2018 :
    even I am not noticing any difference same speaker, camera quality. no difference in battery
  3. Sudhanshu Joshi SDD
    Honeycomb Jun 9, 2018
  4. JelleZon
    OnePlus Accessory Tester Jun 9, 2018
  5. G_jonny_cool_nxOr
    Jelly Bean Jun 9, 2018
  6. Sudhanshu Joshi SDD
    Sudhanshu Joshi SDD , Jun 9, 2018 :
    also front portrait mode is rubish..is making blur everything ..no proper edge detection
    My OP6 and JakovskiFinland like this.
  7. T1514687486610
    Eclair Jun 9, 2018
    exactly
  8. jimmmysil
    jimmmysil , Jun 9, 2018 :
    great update and fast as always! I would also want to make a suggestion it would be awesome to be able to choose battery icon and percentage at the same time in my opinion like it used to be on 5/5T and if lower space is the issue maybe add percentages inside the icons.
    Predict23 likes this.
  9. Qikrion
    Cupcake Jun 9, 2018
    Qikrion , Jun 9, 2018 :
    The notification bar colour scheme on the home screen changed from light to dark. Hard to see in a sunny environment. Will check the settings for manual fix ;)
    Pankaj Madavi and Mireckuk like this.
  10. Lunatico
    Lunatico , Jun 9, 2018 :
    Good lord...Give the update a few days to settle...there is nothing wrong with the battery!
  11. Sudhanshu Joshi SDD
    pls check btry staus..i think it even low now
    A1527082449033 likes this.
  12. alexferdean
    LoloBaboon likes this.
  13. Sudhanshu Joshi SDD
    ohh .if this is normal behavior after updates thn its ok..but in every 1-2 minites 1% btry drop
  14. jimmmysil
    don't think so
  15. Lunatico
    In your case, yes.
    otto2 likes this.
  16. Sudhanshu Joshi SDD
  17. jimmmysil
    G1528773073260 likes this.
  18. Shavir_Afroz
    Froyo Jun 9, 2018
    Q1527367832865 and ScreenOrigami like this.
  19. Sudhanshu Joshi SDD
  20. Himanshu0000608
