1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. Grum235
    Cupcake Dec 26, 2018
    Mr_Cyrox likes this.
  2. FaleshC
    KitKat Dec 26, 2018
    FaleshC , Dec 26, 2018 :
    pill is available for 5T and A/B is available since beta release.
    LegolasX, mayrsona and For Athena like this.
  3. G_Tabrez_Basha_LZnp
  4. angourakis
    Froyo Dec 26, 2018
    angourakis , Dec 26, 2018 :
    Settings -> System -> Developer Options (have to be enabled before) -> Memory use
    Just download the zip from Stable version and flash it on recovery. Be warned that going from Beta to Stable will wipe your data
    Already answered countless times. Use a VPN
    See above
    Someone mentioned to have fixed it booting to Secure Mode and then rebooting again normally
  5. W1545829328345
  6. rAVItEJA74163
    Donut Dec 26, 2018
  7. Kerngehirn3
    Honeycomb Dec 26, 2018
    Kerngehirn3 , Dec 26, 2018 :
    This is still wrong. Oneplus can change it. Downgrade your Launcher or uninstall it and you'll see, old recents are back.
    Why is this in the FAQ???
  8. ErnestOneP
    ErnestOneP , Dec 26, 2018 :
    Greetings, thanks for the hard work and support, I just have to report that there's no Bluetooth connection at all between my phone and radio car after the update
  9. R1517062234839
    Eclair Dec 26, 2018
  10. SoumyaMahunt
    Gingerbread Dec 26, 2018
    SoumyaMahunt , Dec 26, 2018 :
    I am on 1+ 5 open beta 23 and i don't have A/B.
  11. FaleshC
    KitKat Dec 26, 2018
    the thing is you cannot go back to 2.5.xx version in most cases and its Google's design that OnePlus has to follow, they can't change it on their own will.
    and if you downgrade to old versions, the launcher will crash.
  12. Mr_Cyrox
    KitKat Dec 26, 2018
    Mr_Cyrox , Dec 26, 2018 :
    Nope
    A/B partitions aka seemless update is not available for the OnePlus 5/5T
  13. Hafeez Lucky
    Eclair Dec 26, 2018
    Hafeez Lucky , Dec 26, 2018 :
    good work...
  14. FaleshC
    KitKat Dec 26, 2018
  15. HBP87
    Ice Cream Sandwich Dec 26, 2018
    HBP87 , Dec 26, 2018 :
    That's one line command. Type like this.
    smitbhagat likes this.
  16. Mr_Cyrox
    KitKat Dec 26, 2018
    NO
    A/B partitions and treble IS NOT THE SAME
    Google it up
  17. smitbhagat
  18. kika94
    Donut Dec 26, 2018
    kika94 , Dec 26, 2018 :
    I do not see in detail this update "the ability to assign a contact or a group of contacts to a specific SIM card when using the dual SIM" that was available in beta versions. for the people who made the update. Can you tell me if this feature is still present. thank you in advance
  19. FaleshC
    KitKat Dec 26, 2018
    i was supposed to write is not, my bad. only treble support is there.
  20. Kerngehirn3
    FaleshC
    and if you downgrade to old versions, the launcher will crash.​
    Launcher doesn't crash on my end.
    I'm pretty sure oneplus isn't forced to adapt Googles design. They just want to.
