1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. eye842
    Lollipop Dec 26, 2018
    eye842 , Dec 26, 2018 :
    Thanks for the Christmas present, I was expecting it and You did not disappoint in bringing the Christmas Pie.
    Will have to wait some more days before I'll be having me a slice of it.
  2. suresh.anand1918
    Cupcake Dec 26, 2018
  3. Deivuvenkatesh
    Eclair Dec 26, 2018
    Deivuvenkatesh , Dec 26, 2018 :
    Well done one plus. No major issues. Thanks to software team who worked late hours during holiday season to make customers happy. Merry Christmas and New year team[e]1f60a[/e][e]1f44d[/e]
  4. F_Sriram_Jagannath_DPnJ
    Froyo Dec 26, 2018
    F_Sriram_Jagannath_DPnJ , Dec 26, 2018 :
    OP5 STABILITY BUG: (submitted on feedback bug forum)
    Phone randomly keeps restarting after the update. This has happened three times so far after updating to pie.
    Update: the reboot seems to happen even during normal operation of phone during heavy usage (say video streaming). it happened when I tried to switch between different apps.
    Update 2: unable to install new apps from play store and unable to update apps either.
    Dipto_788710 likes this.
  5. Dipto_788710
    Eclair Dec 26, 2018
    Dipto_788710 , Dec 26, 2018 :
    google play store not working. tried all things to fix it like clear cache , data. app always says downloading. wifi or cellular data is working. this happen after update to latest software update android 9.0. please fix it. or do something. moat of the people facing same issue
  6. B1545785921512
    Eclair Dec 26, 2018
  7. addycaddy99
    Eclair Dec 26, 2018
  8. SoumyaMahunt
    Gingerbread Dec 26, 2018
    SoumyaMahunt , Dec 26, 2018 :
    Project treble and a/b paritioning are both different things.
    Project treble is two partition one for root and one for vender partition(for oem codes) .
    A/B is two root partitions for seamless updates.
    See for more info:
    https://source.android.com/devices/tech/ota/ab
  9. F_Sriram_Jagannath_DPnJ
    Froyo Dec 26, 2018
    +1
  10. FaleshC
    KitKat Dec 26, 2018
    FaleshC , Dec 26, 2018 :
    They are not forced to even use android, why do you think all other OEMs also follow Google guidelines, all app developers follow google guidelines? And what is the point if they are not using new feature from Pie?
    and yes it may not crash for you, but with future updates the older launcher will not be supported, thus oneplus updates launcher separately on Play store. There are multiple reports of launcher crash if you had read all the posts from days it launched in 6 and now on 5/5T.
    And you are side loading the apk which is not the official way but a work-around.
  11. B1545785921512
    Eclair Dec 26, 2018
    B1545785921512 , Dec 26, 2018 :
    Bluetooth icon not visible even after its was turned on
  12. FaleshC
    KitKat Dec 26, 2018
    i know that, i was supposed to write it doesn't support A/B.and you are posting same link that i posted above.:rolleyes:
    mayrsona, For Athena and LegolasX like this.
  13. parag008
    Ice Cream Sandwich Dec 26, 2018
    parag008 , Dec 26, 2018 :
    actually it is,
    once after you connect any device to it.
    that is some change.
  14. AkshayMhapankar
    Froyo Dec 26, 2018
    AkshayMhapankar , Dec 26, 2018 :
    Why does OnePlus 5 has only 2 rows of icons in the quick settings and not 3 like 6/6t. Please OnePlus I am used to 3 rows as Android 7 and 8 was having the same. Please add 3 rows to the quick settings please. 1545830375410.jpg
  15. SoumyaMahunt
    Never late to change it, as misinformation gonna cause a lot of spamming.
  16. B1545785921512
    Eclair Dec 26, 2018
  17. parag008
    works completely fine
    you can see a device connected in mine.
  18. B1545785921512
    Eclair Dec 26, 2018
    but in mine it isn't working. Lots of bugs r there
  19. Valentin_Panulescu
    Froyo Dec 26, 2018
    Valentin_Panulescu , Dec 26, 2018 :
    Great as always. A small thing bothers me. The clock on the left! Can an option for changing its position be added? Or is it a Google rule also?
  20. parag008
    And here is the pie we have been all waiting for a very long time.
    many users are facing some issues.
    i hope they will be solved soon.
    for me no issues yet.
    the changed ui is so much welcome.
    many more new and intuitive changes. defienitely worth the time of waiting.
    thank you oneplus for this update.
    many features like new gestures, dnd mode changes, ui changes and many more is so much appreciated.
    kudos to the developer team.
    edit:
    after using it for 3 days now.
    1. screen calibration doesnt seem to work properly qith night mode.
    2. third party apps notifications opening takes a bit of time.
    3. opening any app that has been cleared from recent app takes a second or so to open. so there is definitely a lag.
    4. battery seems to work fine.
    5. adaptive brightness is still in learning mode so it will get over soon.
    6. camera shutter sound stays on even it is off in camera settings.
    all the above bugs has been submitted. before anyone says to submit the bug.
    hope issuses will be resolved soon.
