1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. 440
    Donut Dec 26, 2018
  2. simoniub
    Gingerbread Dec 26, 2018
    simoniub , Dec 26, 2018 :
    at first force stop the play store and then clear all data of play store. it will work
  3. buruaden786
    buruaden786 , Dec 26, 2018 :
    When we scroll notifications down 2 times then whatever downloads are running, it wont show. We have to scroll only one time to view those ongoing downloads.
    Also the navigation gestures feels a little bit laggy and I kind of feel the recent menu is located a bit higher from bottom.
  4. B1545785921512
    Eclair Dec 26, 2018
    B1545785921512 , Dec 26, 2018 :
    check whether playstore downloading is fine or not
  5. ozairewasit352
    Cupcake Dec 26, 2018
  6. G_Maze_Hyde_JbOb
    G_Maze_Hyde_JbOb , Dec 26, 2018 :
    i have 3 [e]1f609[/e]
  7. simoniub
    go to open beta 22 thread and you will find the instructions how to roll back to stable build from beta build.
  8. Dondonari
    Donut Dec 26, 2018
  9. Tricolour
    Froyo Dec 26, 2018
    Tricolour , Dec 26, 2018 :
    After pie update, downloading take long time to start in play store. Net is working fine and browsing play store is working fine. Only on clicking install button, it keeps looping. Don't know whether it is problem with play store or pie update but before updating play store downloading was working fine. This is happening for all the apps I am trying to install or update.
    Dipto_788710 likes this.
  10. F_Sriram_Jagannath_DPnJ
    Froyo Dec 26, 2018
    F_Sriram_Jagannath_DPnJ , Dec 26, 2018 :
    didn't work for me.
  11. sumanyu_sinha
    Eclair Dec 26, 2018
  12. volverOP5T
    Honeycomb Dec 26, 2018
    volverOP5T , Dec 26, 2018 :
    I had this issue in Android Oreo. I submitted the feedback as well and they said it will be fixed in Pie. But I can still see this issue after updating to Pie. Does anyone else has this issue in One plus 5T ?
    Issue is when you click on a link in a message in sms app then the menu is unnecessary long.
  13. F_Sriram_Jagannath_DPnJ
    Froyo Dec 26, 2018
    Same problem with me too. Clearing cache didn't work.
  14. adi_tanwar
  15. simoniub
    use any VPN and select country to Canada if you are so impatient
    Deactivated User likes this.
  16. PokiX
    Jelly Bean Dec 26, 2018
    PokiX , Dec 26, 2018 :
    you probably found it by now but anyway, Ram usage is in developers options (activated by clicking 7 times on build number)
  17. DogeAlpha
    DogeAlpha , Dec 26, 2018 :
    After updating to pie "Voice search" app from google appeared in my app drawer.
    Tried clearing data, cache, uninstalling updates, updating, disabling, etc. It just won't go away.
    And I can't disabling it without disabling google app.
  18. volverOP5T
    For this issue I just restarted the device and it downloaded the apps fine.
  19. Deactivated User
    Dec 26, 2018
  20. G_Егор_Лев_Bfky
