1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. FaleshC
    KitKat Dec 26, 2018
    FaleshC , Dec 26, 2018 :
    check the icon at lower left corner in camera
    LegolasX, mayrsona and For Athena like this.
  2. M1537801500896
    Eclair Dec 26, 2018
    M1537801500896 , Dec 26, 2018 :
    battery is awesome bro the AI will take some time to adapt according to your usage
  3. volverOP5T
    Honeycomb Dec 26, 2018
    volverOP5T , Dec 26, 2018 :
    for this I just restarted the device and then update or new app from play store worked fine
  4. srm_harish
    Froyo Dec 26, 2018
    srm_harish , Dec 26, 2018 :
    it was there for me even when i was in oreo..
  5. Vignesh Vgr
    Froyo Dec 26, 2018
    Vignesh Vgr , Dec 26, 2018 :
    oh okay buddy will do. It seemed really good post 55%, I'll check [e]1f44d[/e]
  6. ALFI.7
    Gingerbread Dec 26, 2018
    ALFI.7 , Dec 26, 2018 :
    which is the homse screen version for the latest update?? kos i haven't received the multi task update..
  7. ramakrishnan.s
    Donut Dec 26, 2018
    ramakrishnan.s , Dec 26, 2018 :
    Thank you for the pie update.
    Since bug reporting is not working properly, posting my issue here. Play Store is not working properly and unable to update apps after this update.
    Tried disabling the app and again enabled, still apps won't update.
  8. Aniket2793
    Cupcake Dec 26, 2018
  9. RahuL1596
    RahuL1596 , Dec 26, 2018 :
    you can use touch VPN app
  10. RahuL1596
  11. ALFI.7
  12. G_Егор_Лев_Bfky
  13. swaraj_c.r.
  14. Sagarxsingh
  15. vyshnav1
    Donut Dec 26, 2018
  16. simoniub
    simoniub , Dec 26, 2018 :
    OP 5 screen is smaller than 5T, 6/T that's why it has only 2 rows. But if you want this you can go to Developer options and change the Smallest width to 420 and you will get the 3 rows
  17. ALFI.7
  18. Sagarxsingh
    Sagarxsingh , Dec 26, 2018 :
    Use Vpn and change server to Canada. Check for updates.
  19. swaraj_c.r.
    swaraj_c.r. , Dec 26, 2018 :
    it will be one by one wait for your turn
    vyshnavvaichu likes this.
  20. N1513510080942
    Eclair Dec 26, 2018
