1411
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. ALFI.7
    Gingerbread Dec 26, 2018
  2. Sagarxsingh
    Cupcake Dec 26, 2018
    Sagarxsingh , Dec 26, 2018 :
    Use Vpn and change server to Canada. Check for updates.
  3. swaraj_c.r.
    swaraj_c.r. , Dec 26, 2018 :
    it will be one by one wait for your turn
    vyshnavvaichu likes this.
  4. N1513510080942
    Eclair Dec 26, 2018
  5. swaraj_c.r.
    how to use vpn
  6. A1512243033407
    A1512243033407 , Dec 26, 2018 :
    Recently i updated my android version to pie from stable to stable but when it said to reboot the device i selected it but after that it is not starting what to do it is showing only oneplus logo at the start 2 times and then it is shutting down again
  7. fungmangfai
    fungmangfai , Dec 26, 2018 :
    Sound setting keep crashing after 9.0 update on my OP5. Anyone having the same problem?
    Imrohit786 likes this.
  8. Sagarxsingh
  9. balaganesh0005
    balaganesh0005 , Dec 26, 2018 :
    i got android pie 9.0 update. after my update got succesfull i got wakeup issue.. if i locked my mobile and after sometime i tried to turn on my mobile by clicking power button or double tap on screen it doesnot respond. but my capacitive touch pad lights are working... my screen doesnot turn on... i need to reboot my mobile to use again.. any solution for this.. i also cleared my cache through wipe cache.. and turned of my ambient display...
    arpit1+ likes this.
  10. K4PTAN
    Froyo Dec 26, 2018
    K4PTAN , Dec 26, 2018 :
    Hey guys i need a little help. My phone running android 7.1.1 oxygen os 4.7.4 should i do install anything different version or directly install 9.0 zip file via recovery mode ?
  11. swaraj_c.r.
  12. G_sunny_arya_iGMp
    Eclair Dec 26, 2018
  13. Aravind_Nair
    Eclair Dec 26, 2018
    Aravind_Nair , Dec 26, 2018 :
    Hi Guys
    Since the update was on an incremental rollout i downloaded the same using oxygen os updater app from play store. During update the phone screen went all blank during half mark. Now i cant switch on my oneplus 5. When i try to switch it on the logo comes for a second or so and it reboots again showing the logo onemore time and it switches off. By pressing volume up and power button i can access the fastboot mode. It there anyway i can make it work again?
  14. R1523176593025
    R1523176593025 , Dec 26, 2018 :
    download touch VPN from the store and set the server to Canada
    then check for system update
    N1513510080942 likes this.
  15. AkshayMhapankar
    Froyo Dec 26, 2018
    AkshayMhapankar , Dec 26, 2018 :
    My point is that in Oreo I had rows with same scaling and changing the scaling makes the text on the screen almost unreadable
  16. Deactivated User
    Dec 26, 2018
  17. tema84
    Honeycomb Dec 26, 2018
    tema84 , Dec 26, 2018 :
    [e]1f60d[/e][e]1f60d[/e][e]1f60d[/e][e]1f60d[/e]
    So far so good...
  18. DogeAlpha
    DogeAlpha , Dec 26, 2018 :
    Well I've been using my phone since 8.0 and it wasn't there until now.
  19. Legend189
    Froyo Dec 26, 2018
  20. jaures113
