1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. sandy0048
    Froyo Dec 26, 2018
  2. balaganesh0005
    Cupcake Dec 26, 2018
  3. J1543375926196
  4. Deactivated User
    Dec 26, 2018
  5. Nazil31
    Eclair Dec 26, 2018
    Nazil31 , Dec 26, 2018 :
    why do you want navigation gestures on the 5? It's a 5.5 inch screen.
    it's has capacative buttons too.
    Makes no sense to have navigation gesture on the 5.
  6. Kiekos
    Gingerbread Dec 26, 2018
    Kiekos , Dec 26, 2018 :
    Is the "Clear all" notifications button missing for anyone else too when you swipe down the notification bar? It used to be on the right side below the last notification, but now I see only "Manage notifications" button there, nothing to clear them all...
  7. Debjeet2001
    Debjeet2001 , Dec 26, 2018 :
    i hv recived the update pie on my 5t there is smoe bugs pf play store not installing apps ...and i feel bit laggy in this update ..i think previous experienced oreo
  8. Debjeet2001
  9. KennyOmega
    Froyo Dec 26, 2018
    KennyOmega , Dec 26, 2018 :
    clean flash.
  10. balaganesh0005
  11. Debjeet2001
  12. Rahul__7
    Donut Dec 26, 2018
    Rahul__7 , Dec 26, 2018 :
    finally !!!
    but mine applocker isnt working!!
    at first it worked but after turning off then again turning on...its not working!!!
    anyone has the same problem???
  13. ambergupta888
  14. simoniub
    simoniub , Dec 26, 2018 :
    in Pie you can change the width to 420 and you will not find any difference between previous ratio
  15. Rushikesh Sharma
    Rushikesh Sharma , Dec 26, 2018 :
    I too have same version see I have this lens
  16. simoniub
    i think you already changed the screen width in the previous build and i think it's more than 420 now
  17. F_Jithin_T_JvGt
    F_Jithin_T_JvGt , Dec 26, 2018 :
    great team work....thanks to team
  18. L1516323439795
  19. Buckybakth
    Eclair Dec 26, 2018
    Buckybakth , Dec 26, 2018 :
    i never ever turned on developer option in my mobile
  20. simoniub
    then you are exceptional bro
