1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. doluisum
    Eclair Dec 26, 2018
  2. V1545844319711
    Cupcake Dec 26, 2018
    V1545844319711 , Dec 26, 2018 :
    yes, facing the same issue
  3. angourakis
    Froyo Dec 26, 2018
    angourakis , Dec 26, 2018 :
    1) Not sure if it's hardware dependent (I guess it's a combination of hardware and software). You may try a Google Camera port with the Night Mode;
    2) It is available already. Just slide right to the Portrait option and choose the front cam;
    3) Not seeing this. I'm still pretty happy with my 5's camera. Again, try a Google Camera port: https://www.celsoazevedo.com/files/android/google-camera/
    Arnova version is the best one;
    4) Settings -> Buttons & gestures -> Quick gestures -> Answer call by gesture;
    5) I guess this is also hardware + software dependent;
    6) My battery life is pretty good. Uninstall apps you don't use, check the permissions of the apps you have installed, use the black theme and a black wallpaper, disable gestures you don't use, use less brightness or just enable Adaptive Brightness...
    8) Does not have any issues with it. Remember that Pie changed the algorithm of auto-brightness;
    9) Does not have any issues either. Try cleaning the front of your phone with a wet cloth.
  4. idadiani
    Donut Dec 26, 2018
    idadiani , Dec 26, 2018 :
    Thank you very much for your time and efforts! Merry Xmas and Happy New! [e]1f384[/e][e]2764[/e]️[e]1f384[/e]
  5. RuBi0_
    Gingerbread Dec 26, 2018
  6. Ishan_007
    Eclair Dec 26, 2018
    Ishan_007 , Dec 26, 2018 :
    you can like original post of me also
  7. kr.rahul27
    Honeycomb Dec 26, 2018
    kr.rahul27 , Dec 26, 2018 :
    no
    but after updating to 9 just do a factory reset
  8. vipul_sethi
    Ice Cream Sandwich Dec 26, 2018
    vipul_sethi , Dec 26, 2018 :
    I m Happy with the Update.. it was worth to wait for little longer... its very fast and smooth.. battery life is great... so far its like the perfect update one would want in there phone.. according to me
    SanyamJain3010 likes this.
  9. V1545844319711
    RuBi0_ likes this.
  10. G_Prashant_Kumar_Roy_75_
    Froyo Dec 26, 2018
  11. Ishan_007
    Eclair Dec 26, 2018
    Merry Christmas
  12. naughtyking777
  13. Ishan_007
    Eclair Dec 26, 2018
    All the things is software related dude...
  14. akaditya15
    Froyo Dec 26, 2018
    akaditya15 , Dec 26, 2018 :
    I got the update from canada vpn thanks [e]1f44d[/e]
    vipul_sethi likes this.
  15. G1545844563687
  16. vipul_sethi
    Download TurboVPN From Play Store then set country to Germany or maybe Canada then you go to setting --> System Updates.. Probably you will find then.. cant be 100% sure that it works everytime sometimes it doesnt work
  17. G1545844563687
  18. TiMiXx
  19. anuraggupta.cs
    Donut Dec 26, 2018
    anuraggupta.cs , Dec 26, 2018 :
    Thanks a lot...
    while I was using camera where I found shutter sound is still there even I have switched off from the camera settings. any clue ?
    S1520830614245 and shadowkgt3732 like this.
  20. PokiX
    Jelly Bean Dec 26, 2018
    PokiX , Dec 26, 2018 :
    what is your carrier?
