1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. sidy1411
    Froyo Dec 27, 2018
  2. Z1517022902564
    Eclair Dec 27, 2018
  3. hareeshpoomangalam
    Donut Dec 27, 2018
  4. simoniub
    Gingerbread Dec 27, 2018
    simoniub , Dec 27, 2018 :
    try to clear the cache data in recovery mode. if doesn't work then do a clean installation, hopefully everything will be fine
  5. chandu rambilli
    Cupcake Dec 27, 2018
    chandu rambilli , Dec 27, 2018 :
    ok i try it now you'r mobile is updated by using this Updater app...?..??
  6. C1545840400255
    C1545840400255 , Dec 27, 2018 :
    Hey guys I m in dire need of help. I just installed the pie update through the vpn (Canada)and I left it for the same. After I did reboot to upgrade now , my phone completes the process and then starts to boot up.
    When it boots up, I can see the one plus logo and then wooosh it switches off.
    I booted it up again still the same issue occured. I went into the bootloader and selected the recovery mode option still it gives back the same issue !!!!!! this is too annoying help me on this please , One plus team and the Community!
  7. saqibrahman7
    Froyo Dec 27, 2018
    saqibrahman7 , Dec 27, 2018 :
    Will try, thanks mate
    simoniub likes this.
  8. sidy1411
    Froyo Dec 27, 2018
    sidy1411 , Dec 27, 2018 :
    Yes.
    I've been using the app for getting all updates for quite sometime now.
  9. Dev1111
  10. simoniub
    absolutely safe. 99% of the members is updating via VPN right now
  11. C1545840400255
  12. chandu rambilli
    now you updated your mobile through the Updater app right now...!!!
  13. sidy1411
    Froyo Dec 27, 2018
    I did it yesterday.
  14. chandu rambilli
    how we can use the vpn app to update the pie in my 5t mobile please tell me clear about it...???
  15. chandu rambilli
  16. rchege
    rchege , Dec 27, 2018 :
    it's not compatible.how did you install on yours
  17. G_Krishna_Solleti_bUoD
  18. G_Viru
    Jelly Bean Dec 27, 2018
  19. simoniub
    just download Turbo vpn from the play store and connect to Canada. when it connects then check the system update
  20. sidy1411
    Froyo Dec 27, 2018
    The official update is out. It's a staged roll-out hence it might take sometime to reach your device.
    If you want to use the official update right now then this app is a solution. it allows for downloading the 'official' update file and locally installing it on your device.
    No rocket science involved, the app gives all the instructions to do so.
