1410
OxygenOS 9.0.0 OTA for OnePlus 5 and OnePlus 5T
  1. Mr_Cyrox
    KitKat Dec 27, 2018
    Mr_Cyrox , Dec 27, 2018 :
    Will come soon because this is a staged rollout
    Read the first post fully
  2. ariesakti
    Donut Dec 27, 2018
    ariesakti , Dec 27, 2018 :
    already finished update to pie...let the software adapt with pie OS.... thank you
  3. _AnthonyMicheal_
    Gingerbread Dec 27, 2018
    _AnthonyMicheal_ , Dec 27, 2018 :
    Haven't received an update yet but waiting for it desparately.
    thanks OnePlus for giving such a unstoppable beast .
    in love with OnePlus and specially with my OnePlus 5T.
  4. Wrawoot12
    Eclair Dec 27, 2018
  5. Ashenmx
    Froyo Dec 27, 2018
    Ashenmx , Dec 27, 2018 :
    Got updated to pie in my OP5.
    Some problems I noticed so far
    1. Poweramp pauses while paying. probably it still does not support pie. Reported to poweramp.
    2. Noticed a little lag when scrolling and sliding here and there on recent apps. Clearing the recent apps did stopped the lagging.
    I know it's to early to say this. but i think battery life on pie is better than that of oreo.
    TDarwald likes this.
  6. Mr_Cyrox
    KitKat Dec 27, 2018
    It appears to be cut from Pie.. Get it?
    Unless I can't seem to find a way to activate but there is... Same where...
  7. ankkeet_99
    ankkeet_99 , Dec 27, 2018 :
    is it okay to update to Android pie from oxygen updater app when you've not received the update push ??
    please advise!
  8. rcy
    Cupcake Dec 27, 2018
  9. Wrawoot12
    Eclair Dec 27, 2018
    Wrawoot12 , Dec 27, 2018 :
    bro simply just install vpn app then select germany and connect it after that go to the setting and open software update u will definitely get pie update
  10. robertoprubio
  11. 88798834
    Donut Dec 27, 2018
    88798834 , Dec 27, 2018 :
    my camera app still makes sounds when taking pictures even the shutter sound is off
  12. drhellcat12
    Eclair Dec 27, 2018
    drhellcat12 , Dec 27, 2018 :
    is there anything I can do to optimise the Google Play services? it's consuming most of my battery! dint face this issue with Oreo! can anyone please help me?
  13. ankkeet_99
    I have updated it with the help of Oxygen Updater app, but what i see missing is this, in the pic. I've done previous updates also but I don't know I'm bit afraid, if that was okay to update it via Oxygen updater app.
  14. soyuturk
    Eclair Dec 27, 2018
    soyuturk , Dec 27, 2018 :
    Great update and thank you so much. To get this update earlier, install Turbo VPN and select Canada server. Thanks me later...
    srambtech and A1526741878634 like this.
  15. Le_zOU
    Le_zOU , Dec 27, 2018 :
    running the latest Android 9 beta and here's what I get when I try a local upgrade :p
  16. Gowtham Shankhar
    Donut Dec 27, 2018
  17. soyuturk
    Eclair Dec 27, 2018
    Install Turbo VPN and select Canada server
  18. Wrawoot12
    Eclair Dec 27, 2018
    first go to file manager then open oxygen updater app folder you wil find that updater package that you downloaded move that file to internal storage( not in any folder) then you will get that package in update log
  19. Wrawoot12
    Eclair Dec 27, 2018
    did you wipe cache in recovery mode of your phone .still if your facing this problem then install antutu benchmark app and run stress test two times and one full test after that reboot your device you will definitely get some better battery backup
    rasulkhan7 and drhellcat12 like this.
  20. Sneha_Verma_
